Question about Panasonic SC-PM71SD Shelf System
Alarm clock on SA-PM71SD?
Is there an alarm clock on this machine? If so, how do you work it. Been looking and can't find anything. help!
Thanks
    President:
  • 173 Answers
Yes it does, if you type in the model number in the google search engine it will open up information about the product. The 6th link down will allow you to download the user manual in pdf format and about 3/4 the way through the first page it will tell you how to set it.
google search
Posted on May 30, 2008
How do I get the alarm to work? I set the alarm for 5am, it did not go off. The sound is off, I have the volume to the highest point, nothing comes out.
Make sure it's on the correct am/pm. Also, make sure that it's not set to radio, or auxiliary, or anything. If it's still not working, I would try to return it.
Mar 09, 2015 | Sony ICF-C318 Dream Machine Alarm Clock...
Alarm
If your clock radio is like mine here is how it works:
Hold down the "Alarm Set Off/On."
While holding this button down, press on the "Hour" button until you get the time you want to wake up. Set the minutes the same way. Be careful- look at the red light to the left of the digital time to make sure it is lit up next to the " AM" spot just to the left (not digital, but usually on the radio metal or plastic itself.
Then let go of these buttons. Go to the right-hand side and slide the button to show if you want to be wakened by the radio or a buzzer. If you want to keep on that schedule, you don't need to do anything. Just move the button to "Off" the night before a day off so you can finally sleep in!
Hope this helps.
May 12, 2014 | SkyScan 34202 Clock Radio
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I need a manual for the Timex T229B clock radio. I can't even figure out how to turn off the alarm. Please tell me how I can find one - preferably free. Thanks, Patty.
I can't find the Timex T229B on the Timex support site. However, the T228B may be similar. To turn off the alarm completely, there is a switch on the left side that must be set to Off. The switch is labeled Alarm on one side and Radio on the other. In between are 4 positions - from front to back, Radio, Buzz, Off and On. When in the Off position the alarm indicator symbol will not be lit at the top left of the display (it looks a bit like a bell). The dimmer switch is in front of this Alarm/Radio switch on this side of the clock.
To turn off the alarm and reset it for the next day, press the Alarm Set/Reset button to the right of the hour and minute buttons. The Snooze button is the large button to the left of the hour and minute buttons.
Timex alarm clock and clock radio manuals are available here: http://www.timexaudio.com/product_manuals.asp .
I hope this helps.
Dec 23, 2010 | Timex T229B Clock Radio
I have a Homemedic Alarm clock Ss4500 And my power went out the other day and then it came back on, and my alarm clock did not reset it self and i can not figure out how to adjust my time. And i do not...
Press and hold TIME while you press HOUR or MINUTE to advance either.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | Homedics Ss4500 Sound Machine Alarm Clock...
Cant turn off alarm on RCA alarm clock model 3715A
Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
It is almost exactly the same model as the #3700 series.
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Nov 05, 2009 | RCA Radio Alarm Clock
Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Jun 09, 2009 | RCA RP5430 Clock Radio
How to work / setBuch radio alarmclock
I just found my manual for the Sharper Image SI785 CD/Radio Alarm Clock with Sound Soother. Had misplaced it for quite a while. Am not saavy enough to know how to post it online, but if anyone needs one, just email back your address and I'll be happy to send it. I remember how frustrating it has been trying to program/reprogram one without it. Looking forward now to knowing how to use this thing :)
Jun 07, 2008 | Audio Players & Recorders
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Oct 23, 2007 | RCA RP5420 Clock Radio
Panasonic SC-PM71SD Shelf System Logo
219 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
