The paper is getting jammed when it starts up in the feeder, like something is stuck. We changed the roll of paper did not help.
Paper get stuck every time I try to print. I notice the paper just slides a bit inside and then on right side it just gets collected and I have to turn printer off to clear paper jam. please help. thanks.
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 28, 2011 | Lexmark X6170 All-In-One InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
    Hello.
    You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
    Sheet Feeder or Manual Feed Slot: Press the
    paper button to eject any jammed sheets, then open
    the printer cover and remove any paper jammed inside.
    Press the paper button again to clear the error.
    Hope this helps.
    May 31, 2010 | Office Equipment & Supplies
    When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
    Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
    Oct 03, 2009 | Minolta Di3010 Copier
    My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
    The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
    Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
    Hope this initial info helps
    Sep 13, 2009 | Lexmark X4650 InkJet Printer
    My HP printer paper get stuck in top feeder whenever I try to fax
    Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
    Also, check to see that the spring loaded lever is in place.
    Clear the jam from the automatic document feeder (ADF)
    1. Make sure the product is turned off and the power cord is unplugged.
    2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
    3. Raise the roller assembly.
    4. Gently remove any jammed paper from the ADF.
    5. Lower the roller assembly.
    6. Close the ADF assembly.
    7. Plug the power cord back into the product.
    8. Press the Power button (c01346625.gif ) to turn the product on.
    9. Try the print job again.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    HP 7680 paper jam
    I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
    I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
    Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
    I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
    The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
    Oct 20, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Landscape copies get stuck
    The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
    May 17, 2008 | Toshiba 2060 Copier
    MP390 paper jam at feeder
    First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
    I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
    Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
    Can you get "IN" to clear the path?
    Mar 30, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
    Unable to print properly keeps printing on one line
    Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
    Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
    23 people viewed this question
    jasbo
    jasbo
