Question about Dell (2336V) Motherboard
The local computer shop indicates that the Motherboard is going out. At times I'm getting problems with the sound.... Every time I start up, it goes through some sort of testing requiring me to select an option, it beeps insessently until I do before I can progress. Is it possible to get this motherboard repaired or replaced?
    Guru:
  • Dell Master
  • 1,705 Answers
Yes is the short answer, repairs will probably cost more than the mother board is worth.
Have a good look at all the solder joints, is there a dry joint, looks like a blob of solder which is
hollow and a bit of wire poking through. If you can find one, re-solder it.
If not, you're into electronically testing each component
Depending on how old your current one is, will depend on whether you replace with like for like or decide to upgrade.
Your problems will be:-
1) Dell uses proprietary equipment, so the replacement will still need to be supplied by dell. Or get a second hand one.
2) It will need to be compatible with your CPU, RAM, PCI cards and HDD/ optical disk interfaces
Good fun, but a nightmare if you're not sure what you're doing.
An alternative is to buy a second had PC and put you current HDD in as a slave keeping the original as a master, even then you need to match interfaces.
Posted on Oct 08, 2010
Pc not starting When I press power button on cpu
If you are not getting the computer to start up but you are getting the fans to whir for a moment and the keyboard lights to flash, then that means that you probably have a bad motherboard. If you had a bad power supply, most likely none of these secondary indicators would be present. I would advise taking the computer to a local computer repair shop and having a professional investigate the problem. More than likely, he will be able to tell you the cause of your problem in short order.
Oct 12, 2014 | Computers & Internet
Pc keeps turning on and off
There's a lot of reason why the computer keeps turning on and off. The following are the common factors -
1. Driver Issue - common symptom is BSOD (Blue Screen of Death) before shutdown. Get the error code that usually starts in 0x12345abc. Unplug any newly installed hardware or any usb device then check. If unsuccessful, boot to safe mode and if computer behaves normally then isolate the problem by performing a clean boot.
How to perform clean boot in Windows
Start your computer in safe mode Microsoft Windows Help
2. Defective internal components such as motherboard, memory module, video card.
- Simplest way to check for motherboard issue is check the computer time. If it keeps on changing then probably a busted battery that needs to be replaced in the motherboard. If not, have it serviced by a local tech or reputable computer shop.
- Perform memory test that is built-in to the motherboard. If the memory is defective, either clean it using a pencil eraser or have it serviced.
- Listen for "beep sounds" before startup. This should give you an idea of what the problem is.
Computer POST and beep codes
3. Insufficient Power / Overheating.
- check the voltage of your power supply and if it is still sufficient enough to supply the motherboard. Check the temperature, if the fan speed is sufficient to cool down the processor. Download the software to check everything.
CPU CPUID System hardware benchmark monitoring reporting
4. Due to Viruses/Malwares
- perform the abort shutdown command to prevent the computer from turning off. go to start - run - type shutdown -i
5. If you are not comfortable doing all this, go to the nearest computer shop. Hope this helps.
Jul 09, 2014 | Computers & Internet
My VIA PM4 CELERON 2.6 GHZ XP PRO SYSTEM WAS INFECTED W A VIRUS THAT CORRUPTED MY DRIVERS AND I LOST HW ONE @ A TIME (CD,SOUND CARD..) NOW I TURN MACHINE ON & GET NO BEEP SOUND & NOTHING ON...
> NO BEEP SOUND
This is an indication that you have a _HARDWARE_ problem.
For example, if you have gasoline in your automobile's tank, but your battery is dead, you cannot start the vehicle.
It's time to take your computer to a PROFESSIONAL technician, to check-out your hardware.
While it's rare to have a computer-virus that can affect the hardware, it is POSSIBLE.
The technician may advise you to replace the motherboard.
Jun 26, 2011 | FIC VIA P4MA (51-80595V24) Motherboard
Hello My travelmate 5720G don't work. I have nothing on the scream, The power button lights don't work. Can't you help me please ?
This problem of yours seems to be the motherboard. In this case, I would advice you to get a new laptop if yours is not under warranty anymore, because the motherboard causes really expensive. But just to make sure, try plugging it in the adaptor, just to make sure, but if no lights come out on the indicators then its a motherboard problem, but if you press the power button and lights come out of the indicator and fans are running, it maybe just a ram or video problem. In this case try reseating (taking out and putting back in) the ram or memory modules. When this doesn't work, avoid touching anything and go to your local computer shop and get a diagnosis, DO NOT ATTEMPT TO TOUCH ANYTHING ELSE FOR IT MAY CAUSE FURTHER DAMAGE.
Mar 27, 2011 | Computers & Internet
The monitor screen is blank. We switched out monitors and still have the same problem.
This is an indication that you may need to replace your video card.
Hope this helps. :)
Oct 06, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Power cord interface with motherboard. I have to constanlty giggle it make it work.Local shop said not worth fixing, but this IS MY COMPUTER
I am going to assume that like many, your plug for the power input on your labtop has come disconnected from the board.
The only way to fix this is to spend a substantial amount of time dissassembling your laptop and resoldering the connector to the board
Most shops CAN do this, it is just a question of finding a tech willing to "go the extra mile" for a client. The procedure is actually extremely easy, the problem being in the ammount of time it takes to physically remove the board.
If you cannot find a computer tech willing to attempt the procedure then look for a TV repair shop, as I stated, the procedure itself is simple. Just let them know that you only want the connector resoldered.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 25, 2009 | Computers & Internet
My computer it wont start!
the three beeps mean there is a problem with your RAM module or modules either check that they have been installed properly or if they have then maybe replace it or them because they/it could be faulty. thanks
Jun 01, 2008 | Lenovo Computers & Internet
Flashing Lights when powered down
The flashing LED is because your system is in "sleep" mode. By default windows Vista puts your computer in sleep. What this means is it doesn't shutdown the power completely it leaves a little going through certain computer components (more specifically the ram) to speed up the boot time when the power button is pressed again.
In XP a the default shutdown scheme is a complete shutdown where power is turned off after the shutdown process is done. If you are using XP you are putting your computer to sleep when shutting down.
As for the boot problem. Newer motherboards have an LED on the actual board to indicate that it is receiving power. If it is of either the power supply switch (at the back of the case) if off or the motherboard connection is loose and the shaking makes it fall into place. (Shaking is usually not necessary and indicates a problem...)
There are a few possibilities I can deduct from your description:
  • the connection from your power supply to your motherboard isn't properly seated and is causing this
  • the power supply switch (not the case switch) is being  turned off and results in the computer taking a few seconds before the internal LED become solid
  • ... the dreaded sign that the power supply is failing and is on it's last legs...
My suggestion is to check all connections and if that doesn't work borrow a power supply from a friend and swap them to see if it boots properly.
(If a friends with a spare power supply isn't an option a local PC repair shop should be able to help you out... but probably for a fee...)
Oct 28, 2007 | Computers & Internet
Dell (2336V) Motherboard Logo
29 people viewed this question
Alun Cox
