Question about Canon PIXMA iP4300 InkJet Photo Printer
Plugged nozzle cleaned and deep cleaned nozzle for pgbk 5 cartridge. got new cartridge but have same problem. Printer unused 5 months.
  • Anonymous Mar 28, 2014
    I need to clean the cartridge nozzle. Where is it located. I don't have a manual.
I took my nozzle to ink specialist and had it cleaned only cost $15.00 but still better than buying new one
Posted on Jun 19, 2008
Inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
The PGBK cartridge doesn't print anything
Do a selftest on the printer. If the Selftest prints out something, uninstall the printer Driver and reinstall it again. If it still did not work checkin the printer to a qualified technican to have a look at it.
May 12, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
#5 PGBK ink is not working
How is it not working? Where did you purchase it from? Is it OEM, refilled, or compatible? These will all vary the answer you get and whether or not the answer will fix the problem. If it is not printing black then the most likely answer is that the black print nozzles are clogged, in which case you should run a few cleaning cycles, and possibly deep cleaning cycles to see if this fixes it. If it is more than that I would point at the kill chip on the cartridge and ask what kind of shape it is in. If the chip is damaged via ESD or possibly missing the printer will reject it. Hope this steers you in the right direction. If not, give more details and we'll see what we can find.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have problem with print-head for PGBK-5. On the test-print it does not appear as the pattern suppose to be (from the top) PGBK, C, C, M, M, Y, and BK. The pattern always appear C,C,M,M,Y and BK. I used...
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too. this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech. head cleaning and servicing will solve the issue
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I am snow bird; printer turned off for 6 months. I shut down properly. Now when doing print nozzel check the top PGBK pattern whole center portion is missing. I have cleande, deep cleaned twice and wiped...
It's manually unclogging.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0062.
Nov 17, 2009 | Canon PIXMA MP960 Printer
MP530 PGBK not recognized
1. UNplug printer at outlet or power strip & wait a full minute.
2. Plug back in and check if ok now.
1. remove cartridge; look for "spit wad" stuck onto the cartridge or in the cartridge cavity in printer.
1. If of the above neither works; use a new cartridge, but don't discard old one.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
PGBK won't print -
Had this same problem with my 5 year old MP830. It was the print head. I bought a new one from Works like a charm.
Sep 10, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Pgbk cartrige
Your printer works with the PGI-5BK cartridges, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Feb 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
308 people viewed this question
old marine
old marine
