Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
D-link dwl 2000AP
I have one of these. The CD has a setup program. But it does not work on Vista.
Could you find me to locate one driver?
The second problem is - I can not find in the manual how to reset the IP of the access point. I have a wired connection which requires to have a static IP 192.168.1.2 with subnet mask 255.255.255.0.
Can this accesspoint be confgured to be the bridge from this LAN poin to the wireless PC. aaaaaaaaaaaaaaaaaaaaaaaaaaaa
Ixi não funfona
Posted on Jun 17, 2008
To reset, simply press the reset button with a pin/pencil. This will revert the IP address to 192.168.0.50, sub net 255.255.255.0
It will also set the admin name back to admin and password to blank
I can't answer other questions however.
Posted on Jun 02, 2008
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
Dec 01, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I want d-link ip for DWL-2000AP
The default IP address for the DWL-2000APis 192.168.0.50
Apr 12, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Network with two D-Link DWL-2000AP
Yes,If it is all on one network. That is the same IP scheme and Gateway.
Just set up a Home Network and give permission for all the PC's to access your "server"
No need to buy anything, just go into the Control Panel, Network Setup Wizard.
Nov 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
IMPOSIBLE INSTALAR
No es necesario controlador. Usted debe configurar el router mediante un navegador web (Internet Explorer).
http://support.dlink.com/products/view.asp?productid=DWL-2000AP
Aug 16, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-link dwl 2000AP
Turn on your AP and push reset button for 30 seconds with pen or any small things (little hole between the antena connector and RJ-45 LAN connector).
Set your laptop IP or PC that you will use to set the AP to 192.168.0.55 subnet 255.255.255.0 Then open your web browser, connect your PC Ethernet to AP Ethernet, remove any proxy setting from your browser temporary, and type 192.168.0.50 enter.
Username is: admin password: none (leave it blank).
Apr 12, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
231 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
