Question about Ovens
GE Stove Model JBP79G W/BB All stove functions work normally except for the oven. The bake element does not light or get hot (Broiler works OK)
  • 27 Answers
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Posted on Nov 01, 2007
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 | Ovens
Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
Jul 01, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore electric stove/oven model 911.9354591. The oven does not work. When in oven mode the broiler comes on. When in broiler mode, the broiler comes on. I have replace the EOC and checked for...
You probably know this, but on an oven unit there has to be two different phases of 120 to make it work. Check the wires that attach to the oven unit to make sure that you have 240 when in oven mode. If you have only 120, find out which wire is not hot and trace it to its source. Is it miswired at the other end? Is it shorted to one of the broiler wires? Usually there is a schematic to show how the oven is wired. Check for anything that is common to both oven and broiler wires and make sure the wires are on the right terminals. With out seeing the sove it is hard to know what it going on. Hope that helps. Robin
Jun 10, 2010 | Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
