Question about MSI G41M4L (890552669976) Motherboard
Does msi g41m4l beep when powered on - MSI G41M4L (890552669976) Motherboard
    Guru:
  • 1,705 Answers
Should do, it's called a post report. Google post reports.
Posted on Oct 08, 2010
How do i solve the motherboard?
MSI Beep codes are fairly standard for their motherboards, but based on the BIOS they have in them. Considering it's only two beeps and no more, it sounds like your memory is bad. See the following page at MSI: https://forum-en.msi.com/faq/article/bios-beep-codes
Nov 23, 2014 | Micro-Star H55M-E21 - MSI H55M-E21 Desktop...
MSI PM8M-V Motherboard Beeping Problem
Hello here is the msi homepage:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Manual
If you download the manual, you need adobe reader, to read the content.
The drivers is available here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=All
Please select your windows system.
The files has to be unziped, before installation.
How many beebs comes, when you start the pc ??
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
The fault could be the power supply, the ram modules, or a faulty setting of a jumper, on the mainboard, or the graphic card.
Do you get the "blue screen of death" ???
Any picture on screen with fault code ???
One long beep, is the ram modules failing.
Try to remove the ram modules, and insert one, and try to boot.
Best of luck
Jan 20, 2013 | MSI PM8M-V Motherboard
Long beep
Hello here is a list of beep codes:
The problem could be the ram modules, or the graphic card, or the power supply failing.
Try remove the ram module, and insert one, and try to reboot.
Please take antistatic precautions, when working on the mainboard.
Here is the msi homepage:
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html#/?div=Manual
For downloading the manual.
You need adobe reader to read content.
Good luck
Jan 14, 2013 | MSI G31M3-L V2 Motherboard
Just bought a new msi main board today transfered all my stuff over onto it and all it does is NOthing wont load anything up.. can some1 help
You can't just transfer it - an old Windows is always incompatible with another new motherboard. The entire Windows will have to be at least Repaired, or much better, reinstalled.
Mar 07, 2011 | MSI G41M4L (890552669976) Motherboard
When i shut down the computer it restarts wndows 7 32 & 64 same problem msi g41m4-l
dear friend this problem not from mother board this is problem by you.re system registry so please install operating system (windows) from another DVD and scan your old and new data with the updated anti-virus.(if you have save data in your system).
thanks
enjoy........
Feb 28, 2011 | MSI G41M4L (890552669976) Motherboard
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
Msi x58 pro beep codes
If you have a way to get online, then google in Computer beep codes, this should help you out.
Sep 20, 2009 | MSI X58 Pro Motherboard
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Powered on MSI K7T Master Ver:1 motherboard and it beeps very frequently
Hi, it sounds like your RAM chips are not installed properly or are faulty, if you have 2 seperate sticks of RAM, remove them and install one at a time to test which one is at fault. make sure you use DIMM 1 for each RAM stick.
Regards mistyman
Nov 26, 2007 | MSI K7T Master-S Motherboard
MSI G41M4L (890552669976) Motherboard Logo
35 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
