Question about DigiLife Full HD Digital Video Camcorder 1920 x 1080 with 3" LCD Touch Screen and 5x
When I power up the camera (Digilife H71z) It enters test mode. I have to torn on/off several times before it starts normally. Any ideas? Is it possible to upgrade firmware? I have FW : V2.00.16 Thanx:)
I got a digilife ddv-511ob about two years ago and it never worked
Why was the camera not taken back for exchange? The only thing you can try is replace the battery with a high grade type to see if it will power up.
Jul 27, 2012 | DigiLife Cameras
I would like to know how to get my netbook off of safe mode please
Hi and welcome to Fixya!
To get your netbook off safe mode, shut it down first.
Then turn it on and after pressing the power button, press the F8 key for several time until the Windows Advance Option comes out. The Start Windows Normally option is selected by default so just press the Enter key and the machine should boot to Windows normal mode.
Hope this helps!
Takasashi
Jul 21, 2011 | Samsung N150 (36725723009) Netbook
I have DigiLife DDV C511 Problem : Camera can not operate with batery, but can operated with power supply (batery charger). Name : Imam Organ Address : Sangatta - East Kalimantan - INDONESIA E-mail : imam...
Halo P`Imam...
dari keluhan Bapak, kemungkinan baterai yang digunakan tidak memiliki daya yang cukup untuk mengoperasikan kamera
Coba ganti dengan baterai yang memiliki kapasitas lebih besar
Kemungkinan lain adalah terjadinya malfungsi pada penghubung daya baterai, dna sebaiknya ditangani oleh teknisi khusus
Terima kasih semoga membantu!
Feb 14, 2011 | DigiLife DDV-C330 Digital Camera
I have a DigiLife DDV-1080HD video camera and it will not power up. Have tried charging the batteries and plugged in directly to the outlet, but nothing is happening. What now?
First thing to determine here is if the power supply have a good voltage output (you can measure it with a voltmeter). The battery could be bad, and shorting out the supply, so take the battery out of the camera and try just the DC supply.
Here is a web blog for dead cameras, and things you can try to get it working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If none of those suggestions work, you'll have to have it serviced. Take it into a camera repair shop or contact DigiLife support. Good luck, and hope this helps.
Jan 09, 2011 | DigiLife Cameras
How to use digilife DDV 7000 cmcorder as a webcam? can't use the flash of digilife DDV 7000 cmcorder
You have to install a driver to use this camera as a webcam. There is a Windows one posted at:
this site
It is actually for a different model, but works. Once you have installed it, your camera will show up as a source when you use a program that captures webcam pics or video. You will need to connect the camera to your computer with a suitable USB lead.
To turn the flash on and off in still picture mode, you press the right pointing arrow on the round selector switch array. There are two settings, off and auto, so you cannot force it to flash- it will only do it when the camera decides the light is low. The flash does not work when filming video.
Sep 13, 2010 | DigiLife DDV-C330/C340 Camcorder
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
Ice maker not dropping ice, the switch is on, and the ice has been in the tray for quite some time now
POWER ON DIAGNOSTICS TEST MODE When the ice maker is first connected to power and the thermistor temperature is 50°F or more, the control will initiate a “Power On” test before entering the freeze cycle. The test will consist of the following sequence:
1)Turn on the motor until it reaches home position
2)Turn on the water valve for 1/2 second
3)Turn on the heater for 1/2 second
4)Verify that the feeler arm was in the “in” and then the “out” position.
5)Verify that the motor was not in the home position and then in the home position.
6)Verify that the motor does not remain on after being turned off.
7)Proceed to the freeze cycle. SERVICE DIAGNOSTICS TEST MODE During the first 15 seconds that power is first applied to the ice maker, the Service Diagnostics Test mode may be entered. The Service Mode is entered by pushing the feeler arm in and out three times within 15 seconds. (only three times). There will be only one fill cycle (5.1 second) in the service diagnostics mode without the waiting period for the mold to “pre-chill”. If the ice maker has already started a harvest cycle and the arm is moving, it may be impossible to start the service mode. (since the NORMAL cycle is already started). While in the “Power On Diagnostics” test mode, the “Service Diagnostic” test mode can be initiated and will override the “Power On Diagnostics” test mode. This ice maker has no replacement parts available and is not intended to be repaired.
Jan 26, 2010 | Refrigerators
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Will not power on
It should power on using internal memory. Your problem is normally due to weak/dead batteries. Make sure that you have fresh batteries, or freshly charged batteries, installed. If changing the batteries out does not eliminate the problem, the camera is a likely candidate for the repair shop.
Bill B.
San Antonio
May 12, 2009 | DigiLife DDV-C330 Digital Camera
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
DigiLife Full HD Digital Video Camcorder 1920 x 1080 with 3" LCD Touch Screen and 5x Logo
89 people viewed this question
Top DigiLife Video Cameras Experts
Tony Parsons
Tony Parsons
Are you a DigiLife Video Camera Expert? Answer questions, earn points and help others
