Question about Norelco Quadra Action 7864XL Electric Shaver
How do I remove the cover to get to the batteries. how do I remove the batteries
  • Norelco Master
  • 1,600 Answers
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Oct 08, 2010
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
I'm trying to clear the memory on my Ti-84 Plus, but every time I hit 2nd then + to access the memory, nothing happens. It doesn't take me to the screen or anything. It justs stays on the blank screen.
  1. Power of device.
  2. Remove primary battery cover.
  3. Completely remove all 4 AA batteries.
  4. Unscrew and remove back up battery cover.
  5. Remove all back up batteries.
  6. Wait 60 seconds.
  7. Reinsert back up batteries and cover.
  8. Reinsert all 4 AA batteries and cover.
  9. Power on device.
  10. Memory cleared!
Mar 13, 2011 | Texas Instruments TI-84 Plus Calculator
How do i take off the battery cover
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove hte upper rear bolt, and swing down the battery box.
5. Remove the top cover, and side cover.
6. Lift battery out, and remove negative cable from battery.
Jan 17, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
My HTC Hero is frozen, is there a way to take the battery out?
Hi. Remove the battery cover then you can remove the battery. Here's how to remove the battery cover:
http://michaelquale.com/911134/how-to-remove-the-battery-cover-on-the-htc-hero/
Aug 27, 2010 | HTC Hero Smartphone
How do I remove the battery on my "04 v star custom
Remove cover panel. Disconnect posotive and negative wires if possible without removing battery cover. Remove battery cover and pull battery out towards you and up.
May 30, 2010 | 2004 Yamaha V Star Custom
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
(4)Replace the battery cover.
Jan 23, 2010 | Nextar MA933A MP3 Player
How to remove the battery door from my sidekick II
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover
Jun 25, 2009 | T-Mobile Sidekick II
Got a new samsung j700 today but i cnnot remove the battery cover I bought a new Samsung behold cell phone today and can't remove the battery cover on the phone.
Remove the battery cover. To do so, press the ridged area on the battery cover using your thumb (1) and gently slide it in the direction of the arrow (2). Remove the battery cover.
Place the battery so that the three brass tabs on the end align with the three brass prongs at the bottom of the battery compartment (1). Press the battery down until it clicks into place (2).
Replace the battery cover. Make sure that the battery is properly installed before switching on the handset.
Thanks.
Mar 27, 2009 | Samsung J700 Cellular Phone
Norelco Quadra Action 7864XL Electric Shaver Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
