Question about Kenmore 24 in. 16012 Built-in Dishwasher
Sears kenmore dishwasher; model: 665.13763K600 (made by Whirlpool). Dishes have debris after washing in all cycles. Arms spin, water is running, dishwasher drains, and I removed the sump assembly to clean the chopper inlet. How do I diagnose it. I put it into diagnostics cycle and am unable to identify the issue.
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: Kenmore ultra wash III dishwasher
Well, the water is clean. The only thing I can think of is that the pump is just not doing its job. The only way to know is put a meter or a flow meter on the pump but heck, I can buy a new dishwasher for under $300 so I think I will just give up. Hate to do it but it is not worth the time and effort anymore. I really appreciate your involvement in my problem and I hope I have not over loaded you with my questions. New dishwasher, here I come........ bah humbug. Mine was only 13 years old, they just do not make them like they use to.
Posted on Jul 12, 2008
reg501
  • 413 Answers
SOURCE: I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Posted on Feb 03, 2009
  • 188 Answers
SOURCE: how do i remove cover on food chopper? kenmore 665
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
Posted on Feb 22, 2009
Dish washer not washing dishes water coming in but the arms are not spinning am thinking the pump may be gone the model is omega dw501wa
Hello; this dishwasher has a pretty poor track record, but since you have it, I'd suggest the obvious solutions first. You only mention that the spray arms aren't spinning. If this is the ONLY problem, and the dishwasher empties properly, the problem has to lie in the spray arms, since the same pump that runs the sprays pumps the water out of the dishwasher.
If you have the manual for the machine, remove the sprays and check that they are clear of all debris (small pieces of bone, plastic, glass, food) that are usually removed when you rinse the dishes prior to putting them in the dishwasher. These small particles are blown into the spray holes when the sprays try to run, and block the holes. Often, they drop back into the spray arms when the pump is off, so they aren't visible on inspection. For this reason, smack the spray arm into the palm of your hand sharply, then shake the arm. If you hear rattling around inside the arm, it's debris. It's a little time consuming, but you need to get it out, and check for this problem regularly.
While the arms are off the fittings, close the dishwasher and start the cycle. Once it reaches the point where the sprays come on, if the pump IS working, and the debris screen on the food chopper is clear, you should hear the water gushing inside.
If you DON'T hear the water gushing, the next thing to check is the food chopper debris screen.
If all else fails, and the washer does NOT empty at the end of the cycles, you probably have a pump problem.
If that's the case, considering the history of these machines and the cost and labor involved in installing a new pump, you should consider getting a new, more reliable machine. Check Consumer Reports next time. (;<)....Good Luck!
Jun 16, 2012 | Dishwashers
I have a Maytag dishwasher Model PDB3600A. the dishes are left with a strong soap residue after a full cycle of wash. I use a powder detergent and Jet Dry. What should I check to solve the problem?
When you open up the dishwasher is there still water in the bottom of the dishwasher????? The screen around the bottom could be dirty. Or the drain line could be restricted, if it drains back to the Garbage disposal make sure it is draining. Are you using hot water??? Check to see if the Arms are turning and the ports are not plugged with debrie.... If the drains are OK and the screen is clean...... I put in about a half gallon of white Vinegar in the wash cycle after it filled with water and used no soap and rewashed the dishes. I ran the Hot water faucet at the Kitchen sink till the water was good and Hot and then on the dishwasher used the heat water feature. It cleaned up the dishes and the dishwasher. I did this on a Whirlpool dishwasher but it should work for any make of dishwasher. Hope this helps... I had to do this several time to get all the dishes back clean
Jan 02, 2011 | Maytag Dishwashers
Dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool disher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Nov 15, 2009 | Dishwashers
The arms do not spin and no water is going through them
Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
Post here is you would like more assistance. Good Luck!
Apr 11, 2009 | Dishwashers
Dishwasher runs but does not get dishes clean
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
Apr 08, 2009 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Whirlpool ADP5966 washer tablet stiil in door
    probably that spray arms are not rotating - to check, open the door when in operation and see if arms move. if not moving, usual cause is debris in spray arm jets. (arms only rotate thro water coming out of angled jets at end.) remove arms and clean for which you need patience
    Apr 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
    Kenmore 24 in. 16012 Built-in Dishwasher Logo
    148 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
