Question about Poulan Bp406 45.4cc Backpack Leaf Blower
I have a poulan pro 30 ppbp backpack blower, i cant get the recoil starter put back together, can anyone help?
SOURCE: recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Posted on Feb 15, 2009
KMusselmann
  • 247 Answers
SOURCE: Poulan Pro Blower starter string
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Pls rate the answer
Kurt
Posted on Mar 28, 2009
SOURCE: replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
Posted on Jun 28, 2010
SOURCE: Broken recoil starter rope on John Deere 5E
No, there isn't.
You have to take it apart, and make sure the spring doesn't get loose, or you'll have to rewind it. There's probably enough to just re-knot it if you're real lucky. Would it be for sale?
Posted on Oct 20, 2010
  • 25 Answers
SOURCE: can't start poulan ppbp 30 cc gas blower
At all? Check the plug to see if it's wet. If so you are getting fuel so problem is spark. Get a new plug and gap properly. What else have you tried?
Posted on May 06, 2012
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How to clean carburetor poulan pro ppbp 30/30
buy a new one on ebay for 20.00,save time and hassle,replace lines too
Jun 24, 2015 | Poulan Garden
How do I replace the fuel line for a Poulan ppbp30?
Open the top of the machine to access the carb, Normally it is easily done with needle nose pliers.
Aug 10, 2014 | Poulan Pro PPBP30 30 cc Gas Powered...
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Can't start poulan ppbp 30 cc gas blower
May 06, 2012 | Poulan Garden
The cord came out of my Pouland Pro model PPb430Vs leaf blower. I took the unit apart put the cord back on the spool, put unit back together. Pulled the cord but the cord did not re-coil?? What...
I will give you instructions for fixing the recoil unit on a trimmer. The blower instructions are the same, just the configuration is different. The key is to maybe have someone help you.
OK...with the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope thru the housing hole and into the hole in the pulley.. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are done
Jun 05, 2011 | Poulan 25CC Gas BlowerVac
I have a poulan pro backpack blower (the 30cc one) and recently tried to start it and the rope extended all the way and won't recoil. i pulled it apart and can see the pulley inside the cover, but how do i...
The recoil spring might be broken or unhooked from the pulley. You would have to remove the pulley to find out what the problem is. But doing this, the spring could uncoil from the spring housing and it is dangerous that it could hit you in the face if you are not very careful. The spring is very difficult to rewind into the housing. I would bring it to a shop if I were you. Whatever you do, good luck.
Nov 22, 2010 | Garden
Recoil broke. wont retract string
Hi, this job requires a little patience and manual dexterity. First, remove the coil from the back pack. Then, keeping your thumb on the inside of the coil, remove the screw that holds the recoil assembly together. Sometimes it may be just jammed and actually snap back as you loosen the screw. If not then the coil needs to be set back into it's groove. If you are able to accomplish this, then you can install your new recoil rope.
Nov 15, 2010 | Poulan 30cc 2cycle Backpack Blower
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Bp406 45.4cc Backpack Leaf Blower Logo
178 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
