Question about Dell IN1910N 19" Monitor
Monitor connected to laptop... In power save. Can't get it to work
    Guru:
  • Dell Master
  • 1,705 Answers
You switch from your laptop monitor to an ancillary monitor using the Fn key functions.
Press the Fn key, while keeping it down, press the requisite number key which has a small
screen printed on it, to switch back, repeat. It acts like a toggle switch.
Posted on Oct 08, 2010
Computer monitor when powered on screen says"saving power" and shuts down?
Try to connect the monitor on other source for signal -laptop or other known working computer.if it posible.
Try with other rgb cable.Moust of monitor go tu stand by or power saving mode when is not presence of signal from computer(h-sync )
If monitor works ok on other source,than problem is in your computer(vga card probably)
Feb 08, 2014 | Computers & Internet
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
Hi I have a toshiba satellite L455D S5976 It just stopped working will not turn on but its got power I connected a monitor usung rgb cable and its got a yellow saying its in power save mode and to hit a...
you should probably get a new screen fixed to laptop, because until u log in and system boots up properly, second screen will not work,
as u tried turning of laptop forcefully, advance boot options must be up on computer, hence not displaying.
Dec 15, 2013 | Computers & Internet
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Need to confirm how to properly connect the computer cables to a Belkin Outlet Surgemaster Energy Saving Surge Protector (e.g. laptop power cord in the "Master slot" and the Dell monitor display...
Sounds like you got it right. When the Laptop draws power it will trigger the Surgemaster to turn on the monitor. The only problem you might have, is being you are using a laptop the power supply might not draw enough power to trigger the energy saving features.
These devices work the best when a tower PC is plugged into the Master slot.
Chris
May 20, 2011 | Computers & Internet
Dell Monitor shuts down with "entering power save mode" command
There are times when you need to install software for a monitor to work with a PC. If you have the software disk that came with the monitor, you can try to install. You can also try changing the power cord to the monitor. Generally, power cords for PC's and monitors are the same. If you use your PC power cord and the monitor comes on saying that there is no connection with a computer, and it was not doing this before, you can get a new power cord for the monitor. If you can, try the monitor with another PC or laptop to rule out a bad monitor.
I hope these suggestions have given you a place to start and that they were helpful.
Brian
Jan 24, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
How do i get my acer 5715z laptop to work with external monitor , the monitor goes into power save mode as goes to log on page . My laptop monitor has a large cracked mark on it thats why i need an...
Cause If you connected the monitor power already is on, you may not get signal. Power plug off the monitor first, Then connected to laptop. Then power the laptop and power the monitor. FN key press hold with your Monitor swicthing key which symbol of two monitor shows on key probably number 5 or 6 maybe 7 check user guide if you have it.
another cause is your monitor may need driver install in your laptop, Some system required that. Check monitor system requirements.
JMC
Aug 15, 2009 | Acer Computers & Internet
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Monitor keeps going to power save mode
the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Sep 26, 2007 | Toshiba (K000006610) for Satellite P25...
Dell IN1910N 19" Monitor Logo
93 people viewed this question
Alun Cox
