Lexmark sc 1275 - I replaced the pc unit with a refurbished pc and still get the low pc warning, and the test page showes 10%. how do i reset the pc clock?
  • 1 more comment
  • greatga47 Oct 09, 2010
    my problem is not low battery. I am getting a pc life warning and after replaceing the pc unit still getting warning. is there a pc clock that needs to be reset? or how can I fix the problem. test page shows 10% life even though the pc unit is new?
    I went to the supplies menu and scrolled. the only items that came up were the pc low warning and yellow toner low warning. no way to get to Replace supply button.
  • greatga47 Oct 10, 2010
    Turning off the printer for one hour did not change things, In the Supplies menu I can only access two functions. PC Life Warning ; and Yellow Toner Low. I have Mark Vision Professional loaded in the computer. When I access this program is there a function that can fix the problem?
  • 4,323 Answers
Hi
If you are getting a low battery error then go to control panel-> power options-> select the power plan and check if you are still getting the low power error. Please provide more details on this issue. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 08, 2010
  • 1 more comment
  • Daniel Scott
    Daniel Scott Oct 09, 2010
    Hi
    The Lexmark would be showing this error for a particular color. To reset this error try this---
    Press either the up or down arrow button on the control panel to scroll through the main menu, search for the Supplies Menu option. Press the check mark button to access the Supplies Menu.
    In Supplies Menu find Replace supply Button using the up/down buttons. Press the check mark button again. Use the same arrow keys as before to scroll through the menu in Replace Supply until you reach the correct "PC Unit" for the photoconductor you replaced. This is either the black, yellow, cyan or magenta PC Unit. Press the check button. Now, press the arrow keys one more time to locate the "Yes" command on the menu. Press the check button one last time to reset the supply counter for that photoconductor. Repeat the above steps for each photoconductor you replaced. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
    Daniel
  • Daniel Scott
    Try the procedure after turning off your printer for 15-20 minutes and then turn it on. Press either the up or down arrow button on the control panel to scroll through the main menu, search for the Supplies Menu option. Press the check mark button to access the Supplies Menu. In Supplies Menu find Replace supply Button using the up/down buttons. Press the check mark button again. Use the same arrow keys as before to scroll through the menu in Replace Supply until you reach the correct "PC Unit" for the photoconductor you replaced. This is either the black, yellow, cyan or magenta PC Unit. Press the check button. Now, press the arrow keys one more time to locate the "Yes" command on the menu. Press the check button one last time to reset the supply counter for that photoconductor. Repeat the above steps for each photoconductor you replaced. Hope this helps... If it does please do not forget to accept the solution or post back for assistance. Daniel
  • Daniel Scott
    Daniel Scott Oct 10, 2010
    After selecting the Yellow color, press the check mark button. Use the same arrow keys as before to scroll through the menu in Replace Supply until you reach the correct "PC Unit" for the photoconductor you replaced. This is either the black, yellow, cyan or magenta PC Unit. Press the check button. Now, press the arrow keys one more time to locate the "Yes" command on the menu. Press the check button one last time to reset the supply counter for that photoconductor. Repeat the above steps for each photoconductor you replaced.
    Daniel
I have a lexmark optra sc 1275 I just downloaded the drivers and tried to print but it takes 3 minutes a page. What is wrong?
Probably nothing. This is a very slow 13 year old printer, claiming 7.5 pages per minute for black and .5 ppm for color. Make sure your settings are for black only to get the maximum speed. Even then, manufacturer claims are often high for print speeds, so 3 minutes a page, especially for color, is probably about right.
Mar 05, 2011 | Lexmark Optra SC 1275 Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
Toner Streaks Printouts - Lexmark Optra SC 1275
Check the fuser for scratches. BE CAREFUL - - - VERY HOT ! ! !
If you need guidance for this, let me know.
Aug 12, 2009 | Office Equipment & Supplies
My Lexmark Optra SC 1275 message windo says PC is Exausted
You will need to get replacement Photo Conductor units.
Jul 24, 2009 | Office Equipment & Supplies
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
I have a Lexmark E352dn printer. The screen showed that the Photoconductor needed replacing which I have done. However the screen still shows " 84 Replace Photoconductor " I have removed and...
the problem is that you need to reset the counter of the photoconductor unit. From the official site of lexmark, i find this solution.
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (pattlnk_11202006_2142-select_button.jpg) and the back button (pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif).
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
2 Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4 Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Hello Do you know how to print a test page? cduffy@marsllc.net
From the operator panel, press Menu> or <Menu to
enter the menus.
Note: Before printing the
menu settings page, make sure
the selected paper source holds
A4, letter, or legal size paper
and the Paper Type setting for
the source is Plain Paper.
2 Continue to press and release Menu> or <Menu until
you see TESTS MENU.
3 Press the Select button.
TESTS MENU is then displayed on the first line, and
Print Menus is on the second line.
4 Press Select again to print the page.
Sep 18, 2008 | Lexmark Optra SC 1275 Laser Printer
My problem with the Lexmark optra sc 1275
Lexmarks use a silicone oil cleaning pad on top of the fuser, try to locate a door on top towards the rear, take it out you might see a long black piece, when you take it out it has a felt on the bottom it is used to clean excess toner off the fuser it should be replaced everytime you change your toner ( usually comes w/the toner).
Oct 11, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
k24674
jasbo
jasbo
