Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard Door leaking
The dishwasher Model #587-15253400 is 2-3 years old. I have a leak that occurs aproxiametly 3/4 of the way through the wash cycle. A small puddle about the size of a quarter occurs on the floor about six inches from the front right corner of the door. The leak is so small I can't trace it. Any ideas?
Thanks
Don
  • 2 more comments
  • ohilty Feb 19, 2009
    Hey, i have a similar problem, except my leaks are larger, sometimes puddle size, happens always in first wash; i took the entire door apart, but cant find the leak yet... any ideas?
  • Anonymous Feb 22, 2009
    I have the same problem. My dishwasher leaks from the bottom of the door. It takes a towel to contain it. I replaced the door seal, but it did not fix it. It seems like the water level is too high. Any solutions out there?
  • jarrettwhitl Mar 10, 2009
    I have the same problem. I really don't think it's the door though. I can see massive amounts of water pouring out of the bottom about a foot back. It comes out about three times during the normal wash cycle and flows out where a red wire meets a plastic peice. I wish I had noticed this sooner because my hardwood floors on the other side of the wall are popping up!
    So, there are alot of us with the same problem, maybe someone out there can help.
  • lutherdaly Apr 17, 2009
    Have the same problem. Ordered a new door seal because it looked torn and new one looks like the old one.
  • 1314 Answers
SOURCE: Help
wow that could be a tough one there is no door lock on a dishwasher only a door latch what happens when you depress the door latch and can you send me a model number so i can pull up the blue prints and see if we can figure out a way to open it try pushing on the door and depressing the latch at the same time let me know what happens
Posted on Jan 10, 2008
  • 423 Answers
SOURCE: dishwasher leaks during the wash and rinse cycles from the front
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Posted on Apr 05, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
SOURCE: My Kenmore under counter ultra wash dishwasher
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Posted on Oct 13, 2009
  • 49 Answers
SOURCE: My Kenmore Quiet Guard dishwasher is 3 years old.
check the spray arm to see that it is not cracked on a seam. take off the bottom panel. there should be four screws. use a flashlight and observe where the unit is leaking from. if it looks like it is coming down the shaft of the motor then you will most likely need a motor seal. some units you have to buy the motor/pump assembly. that can be expensive.
Posted on Oct 27, 2009
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
KitchenAide Dishwasher KUDS01FL leaks water
i have had mine leak (usually out of the left side) I can see it coming off the black rubber seal that ends about 2/3 of the way down the side. ( I have also replaced the inner seal around the tub- that helped as the bottom of the seal would stick to the door when closed and make a gap for water to come out) I also notice that water and moisture comes out at the top of the dishwasher (then it leaks down the side and front) I have heard of many problems with the latch...and I can push mine closed tighter but it doesnt close completely with just the latch, but enough for the wash cycle to work. also just make sure there are no crumbs or something stuck around the liner. good luck mine has been a lemon and i cant wait to get a different brand.
Jun 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water comes out the bottom of the door. not
With very few exceptions, when a dishwasher leaks as you describe, the door gasket needs to be replaced. You have not posted the manufacturer and model number, so it is hard to help much more. Please post back here with further questions.
Good Luck!
May 04, 2009 | Kenmore Dishwashers
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore 24 in. 15932 Built-in Dishwasher Logo
639 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
