Question about Efficient Networks (060-5660-003) (0605660003) Modem
How do you config the modem - Efficient Networks (060-5660-003) (0605660003) Modem
I need to reconfigure my netgear adsl2+modem dm111p v2
first get a wired connection with router//
get into config page 192.168.1.1
username:admin
password: changeme or password
from there you can get into config page and change the settings of the router
Sep 17, 2012 | NetGear DM111P DSL Modem (DM111P100FSS)
ROCO PCMCIA GPRS/GSM Wireless Modem Need Driver for Windows xp/7
download this free trusted software
http://www.ma-config.com/plugins/MaConfig_5_1_2_3.exe
it can resolve your problem
May 23, 2011 | GPRS Modem PCMCIA GPRS Wireless Modem
By which ip using i can open the config page of
First connect the router to your PC, click Start menu button on taskbar click run type cmd now type ipconfig, see the Default Gateway address, open your browser, and type the same address...now the admin page will open....For further help please be with us.Thanks for using Fixya...
Nov 05, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Router ports require configering
I know the ADSL portion of the modem needs configuration. But the routers are settup for default as dynamic and no WEP. At least the ones I have used.
Most belkin routers have a default gateway is 192.168.2.1. Try that and go into the setup. There is also a CD to help with setup.
If you need more help explain more in detail what setup you need.
Oct 25, 2009 | Belkin Computers & Internet
How do I open a port using a Siemens Gigaset 204A modem
you cant open a port on this modem because there is no firewall integrated check your router
or your windows firewall config
plz rate
Jul 08, 2009 | Siemens (120-5830-001) Modem
Modem driver for Huawei FWT Wireless Modem
.Sir ,
I am having Huawei FWT Wireless Modem..For Internet connection(dail up).
Very slow working .Please solve my problem..
Aug 19, 2008 | Computers & Internet
Speadsream 5200 E240
modems are now shipped with the Hardware firewall turned on low to block things,and also Telnet..
Turned it off and then it should also all fixed.
there is methods of hacking this unit as well
Step 1: you have to make sure your IP is set to 192.168.2.2
Step 2: Go to »192.168.2.1/pfwizardj.cgi?code=E···retain=f and set "All Items" under "Profile Configuration Access" click next and choose "Do not require admin login"
Step2: Go to »192.168.2.1/pfwizardj.cgi?code=E···retain=f and do the same thing, except type 192.168.2.2 as your "Constant Profile IP Address".
(if everything went ok, you should now see the new configuration page)
From here, you have to access every configuration page manually.
Here they are:
»192.168.2.1/dhcpcfg.htm - DHCP
»192.168.2.1/ddnscfg.htm - Dynamic DNS (what francoisr wanted)
»192.168.2.1/ipp_config.htm - IP Passthru
»192.168.2.1/updatelocal.htm - Update firmware
»192.168.2.1/ras_config.htm - RAS config
»192.168.2.1/naptcfg.htm - Port forwarding
»192.168.2.1/dmzcfg.htm - DMZ Config
»192.168.2.1/fwcfg.html - Firewall Config
»192.168.2.1/natcfg.htm - NAT/NAPT Configuration
»192.168.2.1/hostcfg.html - Host Configuration
»192.168.2.1/upnpcfg.html - UPNP Configuration
»192.168.2.1/ripcfg.html - RIP Configuration
192.168.2.1/timecfg.htm - Time Server Configuration
»192.168.2.1/fwwizard.htm - Firewall Config Wizard
»192.168.2.1/adscfg.htm - FW Attack Detection System
»192.168.2.1/snoozecfg.htm - Firewall Snooze Control
»192.168.2.1/lansrvscfg.htm - Gateway Server Port Config
hope that helps
Aug 02, 2008 | Efficient Networks SpeedStream 5200 Modem
How to reset UtStarCom W3002G4 modem
at the back of the modem, you will find a small reset screw, reset with a pen or a pencil and restart the computer
Feb 04, 2008 | Computers & Internet
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Nov 08, 2007 | Computers & Internet
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Efficient Networks (060-5660-003) (0605660003) Modem Logo
42 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
