Question about Sony Cyber-shot DSC-H9 Digital Camera
I own a sony digital dsc-h9 camera. the lens does not extend or retract. Also the aperture doesn't open. any ideas how to diagnose and fix it. is it something that can be done by a non expert?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
    Brigadier General:
  • 3,006 Answers
It's most likely that your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
DSC-H9 flash doesn't work
You can buy a flash unit for your camera from E-Bay listed under camera parts for your make & model but this may not be the cause of your problem. you really need to have it checked before you start buying parts that you may not need.
Jan 25, 2013 | Sony Cyber-shot DSC-H9 Digital Camera
I have a sony dsc-s90. It will work fine for 3 - 5 min. and then a black screen will appear with "turn power off and on again". Once done, it happens again.
Usually a lens sensor. Clean with maybe some compressed air. If you trust your skills you could open the unit and clean cabinet where the lens retracts and extends.
Mar 25, 2011 | Sony Cyber-Shot DSC-S90 Digital Camera
My camera lens wont extend
The lens block is faulty replace it
Feb 14, 2011 | Sony Cyber-shot DSC-H9 Digital Camera
How do I repair the lcd screen for my DSC-H9 sony camera that is broken and only shows a black screen with cracks throgh the lcd area
You need a set of philips screw drivers size #0,#00 and #000. Buy parts camera with stuck out lens but good lcd from ebay. Then replace the lcd screen and the led back light assembly connected by flexible circuit and flip up connector.
May 20, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Lens will not retract completly on sony cyber shot DSC-W55 after being dropped while lens extended
Only try this if your camera is out of warranty. Turn camera on, and extend lens fully, now grab outer most element and pull out. Sometimes you can reseat the lens in the track at the correct point. I used to do this all the time to my older digital cameras.
Nov 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony dsc-w5 lens not returniing
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 17, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc p5
probly has salt spray sticking the lens cover shut
Sep 19, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cyber-shot  DSC-H9 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
