Question about Zebra 105Se Thermal Printer
Hello, I'm using a D-Link DP-301P+ to a Zebra 105se but don't know how to get the configuration page to setup TCP\IP. Please help
  • 38 Answers
SOURCE: Zebra 105Se
The 105Se does not have a downloadable firmware file.
Sorry.
Posted on Mar 05, 2008
SOURCE: Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Posted on May 20, 2008
  • 38 Answers
SOURCE: No response from 105Se
The 105SE was manufactured in either serial or parallel interface configurations. Settings for a serial version are irrelevant for a parallel port unit and vice versa.
1. Verify parallel port and cable are working (test with a different parallel port printer using the correct driver for that printer.
2. Verify you have the correct Zebra driver installed for the 105SE.
Place the printer into Mode key Self Test and verify data received is ZPL II.
Steve W
LazerTek, LLC
Posted on Jul 17, 2008
SOURCE: Zebra 105SE configuration settings
Please scroll the printer parameter untill you fine LEFT POSITION parameter and adjust as you needed.
Posted on Nov 25, 2008
Sakeninja1
  • 5 Answers
SOURCE: Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Posted on Mar 25, 2009
Change ip address
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
Aug 17, 2013 | D-Link DP 301P (DP-301P) Print Server
I have connected the d-link to a KOT printer,my network cannot find the server.And according to the manual I cannot browse the default ip of the DP-301P+ sever.please assist me immediately.
I have D link DP- 301P Print server I am using it in Epson M188D Printer for KOT Printing but its shows some times printer not found on network, please help me to solve the problem.
Ajay
Mar 22, 2011 | D-Link DP 301P (DP-301P) Print Server
I have print server DP-301U Pls let me know the default IP address for configuration
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Feb 09, 2011 | D-Link DP 301P (DP-301P) Print Server
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
More specifics on adjusting the Left Position on Zebra 105Se.
I have a Zebra 140X and we would hit setup then hit the left or right button until you get to Left Position option. on mine it looks like its the 28th option going right.
Let me know if that helps.
Sep 22, 2009 | Zebra 105Se Thermal Printer
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
I forgtten the IP of the Print Server D-Link 300U. Please tell me , that how to reset the IP
usually by resetting it. pushing the reset button on the back it (tiny hole on the back) for 30 seconds, while plugged in to power,
Jun 15, 2009 | D-Link DP 301P (DP-301P) Print Server
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
Jun 04, 2008 | D-Link DP 301P (DP-301P) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
No printing threw terminal service
do you have the options set correctly on the remote computers assistant to use local devices
Dec 25, 2007 | D-Link DP 301P (DP-301P) Print Server
Zebra 105Se Thermal Printer Logo
212 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
