I have a Hotpoint Ultima WT761 Washing machine. The belt has not broken but is damaged and the edge is stripping off. It has come off the drum and motor spindle. Clearly its time to get a new one which I will do tomorrow. However as a practice I tried to refit it and its very short and "impossible" to get back on. There is no elasticity in it. Do new belts have more give in them, or is there some trick to refitting? It didn't look like unbolting the motor, fitting it and then refitting the motor was that practical. Thanks in advance!
  • Washing Mach... Master
  • 2,342 Answers
Not absolutely sure of your exact model, but most washer belts on put on by putting them on the motor the stretching to the tub pulley and holding it there while you move the pulley which then stretches the belt to fit for you.
Posted on May 05, 2017
  • 18 Answers
SOURCE: REFITTING THE BELT ON HOTPOINT WMA 40
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Posted on Jan 02, 2009
  • 106 Answers
SOURCE: refiting door seal zanussi1050 fls1183w frontloader
You might find this useful, all here on fixya.
http://www.fixya.com/support/t1298211-zanussi_washing_machine_door_seal
Posted on Mar 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Drive belt came off spindle on Hotpoint First
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Posted on Sep 13, 2009
57 varieties
  • 1653 Answers
SOURCE: Hotpoint Ultima Wt761 is displaying F-08 what can
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Posted on Oct 25, 2009
  • 196 Answers
SOURCE: My Hotpoint ultima washing machine
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. H20 normally means not filling but sounds like the switch is faulty. Hope this helps
Posted on Mar 02, 2011
Testimonial: "Thank you i will try what you said many thanks"
My hotpoint ultima wt761 door catch has broken how can i open the door
If you have a broken door catch you can get the door open by feeding some garden wire around the right hand outside of the door (between the door and the metal casing of the washing machine).
Once you've fed it in round the top right and bottom right curved corners pull the two ends of the wire to the left, so that the wire pulls against the lock mechanism, and the catch should release.
Feb 26, 2011 | Washing Machines
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working ,no display no power ,nothing ,ive changed the fuze in the plug but to no avail, please help .
possibly mains lead you need to check there power coming out from mains filter the other end of lead-if not you can purchase a lead complete
Nov 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Wt761 is displaying F-08 what can I do any ideas please
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Have a hotpoint wt761 washing machine which is displaying a f-08 error code
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
Jan 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
