I own a 4 year old 61" Samsung HD DLP TV. I replaced the bulb about 12 months ago. At bout 2 months ago the TV has started turning itself off sporadically. Sometimes it will go a several hours in a row and then turn itself off or it will go off every 5-10 minutes. I removed the small back section and dusted the inside. That seemed to help some but with in a short amount of time it is back to turning itself off. The replacement bulb should be a samsung approved bulb. Is it a bulb issue or an over heating issue? How do I diagnose the problem? and if it is a heating issue how do I repair it? Thanks, GP
  • gordon_pe151 Oct 08, 2010
    Thank you very much for the information. Do I need to get a repair person to do this or can I buy these parts and easily do it myself? How costly is this repair?
  • gordon_pe151 Oct 09, 2010
    Thank you very much for your help.
    GP
  • 19,396 Answers
Hi GP.
I was going to write on this yesterday, then I left because the problem is common on Samsungs, but there are more different problems causing shutdown.
When you call Samsung they usually answer that the problem is likely Digital Board (about $400) or DMD Board (other expensive part), and give you the highest possible quote, so to cover the repair problem whatever the problem.
If problem happens after lamp replacement, then it is often either a defective lamp cage safety switch, or a faulty ballast board.
There is a huge number of posts on the problem, all pointing at different faults. If for example convergence or PSU board started failing one year after lamp has been replaced, that would be the problem.
Concluding, unless there are additional symptoms, the only way to say what the problem is is by disassemblying and testing the set at component level.
Let me know model number of the set if tou need more detailed info.
Also let me know if there are additional symptoms (eg. BLINKING CODE, colors not matching or distorted picture before shutdown, popping noise, audio but no picture, etc.)
Regards.
Ginko.
Posted on Oct 09, 2010
  • 11,800 Answers
It's neither of them - it's a problem in the power source:the filtering capacitors have aged and they have lost part of their isolating characteristic so a much bigger current is shorted to the ground thru them.
Because of that the power source is overstressed and when - due to the content of the program you are watching, like in case of a very bright scene, or very loud one - more current is needed , the trigger level for the protection system is reached = the tv just shuts down.
You need to replace every singe electrolytic capacitor,
Posted on Oct 08, 2010
  • Azrael SRL Oct 08, 2010
    The parts are easy to find - you can get them very cheaply online ; here is a site
    http://www.westfloridacomponents.com/Ele...
    . They will cost you less than $25 all.
    But to install them you must unsolder the old ones and , because of the very high current that pass thru them, their soldering must be perfect. And you must not overheat the board while doing that. If you aren't sure you can do that properly then call a repairman - it's a 2 hour job to do it well and what will cost you depends on what the local guys charge per hour.
  • Azrael SRL Oct 09, 2010
    It will be easier if you would let the repairman obtain the capacitors himself, no more trouble for you for a small saving.
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
Samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Feb 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
