Question about Whirlpool LGR8648L Gas Dryer
Whirlpool model LGR8648LW gas dryer heats for first heating cycle Then won't heat again until it is not used for awhile.
docjohn174
  • 943 Answers
SOURCE: Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Posted on Oct 06, 2008
Illeagle
  • 525 Answers
SOURCE: gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 12, 2009
garing
  • 998 Answers
SOURCE: my dryer doesn't produce heat. the coil ignites
replace all 3 gas coils
Posted on Aug 05, 2009
garing
  • 998 Answers
SOURCE: HEAT WORKS FOR AWHILE THEN STOPS
coils on gas control get hot and stop working you will need to change them...thumbs up
Posted on Aug 10, 2009
SOURCE: whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Posted on Oct 05, 2009
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Gas Dryer has heat at beginning of cycle then no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
My whirlpool ler8648pg dryer has heat but not enough to dry larger loads. Takes multiple cycles to dry. Does anyone have a solution? Thanks
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 24, 2010 | Whirlpool LER8648P Electric Dryer
Gas Dryer no longer putting out heat.
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
GAS DRYER MODEL LGR8648LW DRUM SPINS BUT NO HEAT. VENT IS CLEAR. WHAT CAN i DO?
If you have a gas dryer...
If your dryer is electric..
heatman101
Apr 15, 2010 | Whirlpool LGR8648L Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Whirlpool LGR8648L Gas Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
