Question about Kenmore 64802 Top Freezer Refrigerator
I keep finding a lot of water at the base of the refrigerator under the storage trays. Where is the water coming from? how to stop it?
    Sergeant:
    Champion:
  • 351 Answers
Hi defrost water. drain stopped up take everything out of freezer take bottom up in freezer get heat gun or hair dryer out and start defrosting once you get the ice gone blow out drain hope this helps jim
Posted on Oct 08, 2010
My stand alone kitchen aid icemaker is filling up with water. It is making ice but it keeps filling up with water as well. I had a plumber come out last week because the ice maker was leaking. He fixed...
The drains on items like this get a sludgy residue built up in the drains. Make sure its clear. Empty the bin and you should see the drain port run a small amount of hot water in it. Not a lot as it could leak from the drain tray if it has one. If the drain is clear then it could be a nice maker issue where it's dumping too much water in the tray to harvest. Excess would spill over.
Sep 26, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker leaking after filling
Most likely the=> 67005154 Dual Waater Control Valve
found on the rear of your refrigerator and down near the floor is becoming worn out and not closing all the way. Are the ice cubes also beginning to stick together? I need you to watch this problem to see if it becomes worse and gets stuck open allowing a lot of water into ice maker. The ice maker determines how much water flows to ice maker about 7 seconds time but if mechanically defective it will not close all the way even when off. I will stick with a solution but will meed you to respond, Thank You, Sea Breeze
Dec 10, 2012 | Admiral 26 cu. ft. Side-By-Side...
A lot of water collects in the ridge under the veg-fruit crispers. I have to constantly sop it up with towels. This model does not have a drip tray under the storage area
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | GE GTH18EBT Top Freezer Refrigerator
The refrigerator always gets water in the base under the crisper drawers and on the shelves. How do I stop it from doing this?
There are two reasons. One check defrost is working properly. And second defrost tray has no crack.
and also while inserting defrost tray 100% pushed in.
Jan 22, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
Water coming into refrigerator
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Jan 17, 2009 | Rival 38651-C 6-Quart
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
