Question about Samsung YP-K3 MP3 Player
Doesnt turn on
Charges but doesnt power up(turn on)
What you do is you go to the bathroom or bedroom and a have a big fat wank and beat some *** out m8 trust it solves all your worries
Posted on Jun 25, 2008
  • jackworth08 Jun 25, 2008
    finger your *** m8
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My iphone4s doesnt want to turn on
Maybe it's just because of lacking power, you should give the 4s a little time to charge some power and then, you must can turn it on, if not, just pulled out the charger and turn on the 4s, then continue to charge...
Jun 05, 2012 | Apple iPhone4 4G iPhone 4
Hp hdx16 no power
The power supply charger should be checked for correct voltage, If it's dead it will need to be replaced. Remove main battery first, now turn on! if no change, you will need a professional to assess.
Feb 22, 2012 | Computers & Internet
My mix max doesnt turn on. it was working and all of a sudden it said "connect to usb". i did then it turned off and it doesnt turn on anymore i tried to charge it but it still doesnt work. HELP!!! please.
If this doesn't help, the MixMax must be opened up. By CAREFULLY prying the corners loose, you can remove the back. You will break several of the smaller retainer clips during this, but it's OK. The main retainers will hold the unit together just fine once completed. Once opened, unplug the battery. NOTE THE ORIENTATION of the red and black wires. Use any 5V 500ma or less power supply and connect to the battery. Charge it for at least 30 seconds. return the battery to the unit, and reassemble. DO NOT TURN IT ON. Plug the USB cord in and let it charge completely.
The MixMax will disable the power if there is an unexpected power interruption, then the battery will run completely dead. Once dead, it cannot detect the USB when connected.
Jul 30, 2010 | Disney Mix Max Digital Media Player
Sons projects - Car doesnt crank over without a boost
have the battery charged andtested first. once a good power source is in there, take a volt meter and test your battery terminals for at least 13.5 volts. if not replace the alternator.
Jan 25, 2010 | 1992 Mercury Topaz
My psp doesnt turn on anymore
Batteries lose their capability to charge to their highest capacity after each charge. I would reccomend a new battery.
Mar 14, 2009 | Sony PSP (Piano Black)
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
Does not turn on at all
listening to music when it suddenly turns off. it doesnt wanna turn on. tried charging it but it does nothing. its just a black screen. ..help?
Jan 26, 2008 | SanDisk Sansa m250 MP3 Player
Doesnt turn on
you can try taking out the battery for a few days then charged the phone up while pressing the power buttom if a result leave it to charge for a while if no result check your charger if is working correctly maybe damge
Sep 07, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Samsung YP-K3 MP3 Player Logo
24 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
