Question about Jenn-Air Ovens
We have error code EE214 &M214,we changed conrol board,still same proble,please help us
I also have this same problem. Just got the new (expensive!) control panel in and it didn't help a thing.
Posted on Nov 10, 2010
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Need a contol board for frigidaire cfeb786jgb3 oven
Contact your mfr and they can send them to you or even let you know of a dealer in the area that as the parts.
Feb 25, 2013 | Ovens
F1 code flashes
Hello & Welcome to FixYa
F1 error in your oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
Nov 06, 2011 | Dacor DO230S Oven
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
F2 E0 error code on display pannel
F2-E0 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | KitchenAid Ovens
My oven started beeping constantly with changing codes, time count-down, lock? display, then error codes F2 E3. Can't find these error codes anywhere. I finally shut off the breaker to make the beeping...
F2-E3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Whirlpool Ovens
Amana whirlpool oven F1 error appears and it won't stop beeping
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Whirlpool RBD305PD Electric Double Oven
F10 error message oven 790.9612
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Kenmore Ovens
F3 code I have replaced 2 high voltage transformers,2 caps,2 mags,2 lo voltage transformers, 3 relays, and I/O board. and still have a F3, i have reprogramed the I/O board twice and my amp clamp reads 15.1...
holy **** that was a very expencive fix huh. I hope you spent the 50 bucks and have a service manual. What about the diodes, have you tested or changed those. That looks like the last thing i would change and there only a few bucks so i would change them at this point anyway. Are you blowing a fuse at all.
You need to narrow the problem down, not just toss money into the toilet replacing good parts. If your reading 15.1 amps then you have no problem in the high voltage system. Unless the amps are ramping or erratic. Your I/O board is bad if its reading 15.1 and triggering an f-3 fault. You said you replaced it though. Contact who you purchased it from and see if they will help. Its a $420 board and $160 for each HV Transformer they should help. I would guess that your I/O board it bad. You also said you changed relays. Did you change the K2 relay.
Hope you can solve the problem quick. Hopefully this helps
Nov 03, 2010 | TurboChef TORNADO Electric Oven
Error codes how to reprogram oven electric oven the code F30 appears on led display
Hi
The F-30 error code states its a Open/shorted probe connection. Check resistance at room temperature & compare
to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor
wiring harness between EOC & Sensor Probe connector. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Also you can see the probe in the oven in the top left or right corner. It is pencil sized and about 5 inches long. You would need to get to the back of the oven to replace it. It has two 1/4 in screws that hold it in place. You then plug it into the control board and you are ready for baking again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Ovens Logo
336 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
