Question about Braun 8585 Electric Shaver
Sideburn cutter part needs to be put back on. It became loose and now has fallen out. I could fix this myself if I knew how to open shaver.
  • Braun Master
  • 1,610 Answers
If the sideburn cutter has come off, it is because it is broken. You will need to replace it. You will find the item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For instructional video on disassembling the shaver, also see shaveroutlet.com tutorial here:
http://shaveroutlet.com/video_tutorials
Posted on Oct 08, 2010
How do I disassemble a wahl 4000 shaver
Remove the foil and cutter as usual. Then remove the two metal clips on the top of the shaver body. The front and back cases can now be separated at the top and will come apart
Oct 13, 2014 | Wahl Cord/Cordless Custom Shave System...
Can I replace my Remington Titanium MS 5200 shaver's battery myself and where do I buy the battery?
You will find compatible batteries for model MS-5200 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To open the shaver body, remove one screw on the back. Also partially remove the 4 outer screws found on the metal plate under the cutters. Once these 4 screws are removed you can partially remove the top part of the shaver body (the parts with the trimmer on it). Then you will need to gently pry off the rubberized grip on the front of the shaver. This will reveal two more screws. Remove these to seperate the front and back of the shaver and access the batteries.
You will need to remove the wires from the batteries by melting the solder with a soldering iron. Solder in the new batteries and reassemble. Charge for 24 hours before use
May 16, 2011 | Remington MS-5200 Electric Shaver
Remington Titanium R-450: sideburn trimmer parts fell out. How do they fit back together?
Remington Titanium R-450 - I have one of these that I got on the cheap. The rechargeable batteries died and the thing would not rev up. Batteries need to be soldered in - I opened it up and cut out the 2 cheap nicads and it now runs like new - just not cordless.
Oct 31, 2010 | Remington Health & Beauty
Will not turn off
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Was this helpful? Yes No 4 people thought this was helpful
Add a comment
    • davjones101
    • 1 minute ago
    Thanks ,very helpful. Let me just add a vital bit of information On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic. I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
    Reply
Oct 17, 2010 | Braun Syncro 7526 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
GOOD LUCK!!
Nov 28, 2007 | Braun Syncro 7526 Electric Shaver
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Braun 8585 Electric Shaver Logo
460 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
