Question about Music
I HAVE CASIO HZ 600 HAS A PROPLEM NO ANY ACTION DEAD BY MAKING SHORT CIRCUT AT THE POWER REGOLATOR ON THE MAIN BOARD AND I DIDNT KNOW WHAT HAPENED PLEASE HELP ME TO FIX IT THANKS.
  • Music Master
  • 5,603 Answers
The way you troubleshoot these problems is to use a current limited power supply to drive say 1/2 amp into the circuitry. Then you use a millivoltmeter to find the point where the tiny voltage developed across the short goes to zero.
Sometimes you can monitor the tiny voltage and use freeze-mist to cool suspected components and look for the tiny change that occurs with temperature change.
I have other methods but they use expensive probes that you can actually follow a pulse on the current path to the short.
Posted on Oct 09, 2010
Power switch for Casio key board not switching
Without knowing the model, age of the keyboard if it is moved a lot, etc it's hard to say. Most common problems are damaged power jack(or cracked trace on the supply board near the jack ), bad AC adapter, bad power supply board(shorted semiconductor, regulator, etc ) and rarely a bad power switch. You could try a new ac adapter but it might be a waste of money(if you have access to a multimeter check the output of the adapter before buying a new one).
Jan 02, 2015 | Music
My Privia px200 won't turn on, what is the problem
First get a new 12V DC power supply (AC Adaptor model AD-12) to test.
Otherwise it needs repair by Casio technician. Main PCB board may need to be replaced.
May 29, 2014 | Casio PX200 Privia Digital Piano with...
I have two B215 600 watts speakers. Smoke started to come out of one when it was in use. I continued to use the other one, and about an hour later, the bass on that quit working. Any help with...
Sorry, those speakers are rated at 250 Watts RMS continuous, NOT 600. The speakers are nominally 8 ohms. The PMP6000 will deliver about 250 watts RMS to an 8 ohm load so the speakers should be able to take this as long as you had one per side and NOT using bridged mode of the PMP6000. It is possible that you fried the amp, although the PMP amps have a speaker protection network that shorts the output should the amp hard over. It is strange that you could draw smoke with the setup. Hopefully you were not generating very low frequencies that were below what the speaker could handle OR that you did not crank up the bass with the EQ such that frequencies below the speakers rating were sent at high levels. Your speakers are rated for a low end at 55 HZ. You should have the eq cut the gain below that. The leftmost EQ (50 Hz) should NOT be higher than center... if you boost that one, you likely will be buying new speakers. If you need power below that, then you need to be using subwoofers. Hopefully you haven't damaged the PMP6000... I assume that was the amp you were using, although you haven't stated that. At this point, unless the stuff is under warranty, you nee to open the speakers and see what has blown... could be the woofers or the crossover network...Use an ohmmeter to check the woofer DC resistance... should be between 7 and 9 ohms. If it is open circuit, the voice coil is blown.
Sep 19, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
My behringer pmp3000 has circut board damage(some burnt spots) on the speakon connections board and the amplfiers board. it does not seem to power up(no lights). are these parts repairable or replaceable,...
i own and at this moment have a behringer opened up because of the same problem you have and ill tell you that 6 electronic shops and all the guys at the forum have not successfully fixed these mixers and its not that its difficult its a manufacturing design flaw in the second board at the output A and output B ports inside the mixer.this board which processes power output from the mixer console out to speakers cannot handle the dual 600 watts (1200 total watts) that is running through it and blows the main coils if you replace the coils it will blow when and if you hit a low/high frequency and it usually happens in the middle of a show when you up the bass or the highs which cause the main transformer/resistors to process too many watts to the coils,either the resistors or the coils blow so the guys at the music/electronics forum are exactly correct but you can get the main board for $44.00 at amazon or ebay so you wont have to spend time and money replacing resistors etc
Dec 26, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
I have a Casio PX-310 on the service bench . I
As you probably know the regulator also supplies power to the other ICs on the board. If the fuse keeps blowing that means that one of the parts drawing power is shorted. By looking the pin configuration up for each IC you can find which one is the + and which one is the- etc. The faulty IC will be showing voltages on the other pins where they shouldn't be. That is usually the defective part. You will also want to check parts that are related to or in the same circuit. The worse case scenario is that the main IC is shorted. Without the schematic its a long arduous troubleshooting procedure but it can be done and I just thought I would suggest it. I mean know pffence and just wanted to help somewhat.
Jul 09, 2009 | Music
Casio-ma150,main cirquet board-Q-4 transister deamage
Try emailing CO-Windler@Weltenschule.de. Also visit his website at http://weltenschule.de/TableHooters/index.html. Look at the TableHooters modification FAQ. He has some good info on circuitry and components. I hope this helps somewhat.
Apr 22, 2009 | Casio Music
Casio CT-670 Tone Bank keyboard completely dead
How familiar are you with schematics? I've just found my CT-670, There where marker marks on the keys. I cleaned it up. I took it apart as one channels had no sound. I love this machine. I want to find a manual for it also schematics would be very helpful for me too.
I would suggest looking inside for burns on semiconductors. or loose soldering. I need to replace a chip that has no cross reference... that I've found yet... I think it's an amplifier but need to spend more time on it....
Mar 14, 2009 | Casio Music
Finding a way to hook this up
Send main 1 out to your Crown. Jump Mon send to PWR am insert.
Mar 11, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
50 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
