Question about Maytag 14.8 cu. ft. / 419 liter Chest Freezer MQC1557AEW
Hi, just moved. Everytime we plug in the freezer into wall socket. freezer tripped. My husband is wondering if freezer need to be in a 20 plug instead of 15.
  • bvsaunders_5 Oct 08, 2010
    yes it a GFI braker! bev
    Sergeant:
    Champion:
  • 351 Answers
Hi 15 should do it is it aGFI braker? jim
Posted on Oct 08, 2010
  • sparks194520 Oct 09, 2010
    try to plug it in another rec that not a gfi see if it works. just may be a bad gfi jim
My freezer keeps overloading our switch board, whats wrong?
The freezer has a compressor which will draw quite a lot of current in the first half-second when it starts.
Either: Your freezer has a electrical problem and needs to be fixed,
Or: there is already too much drawing on the circuit that you are trying to add the freezer to, and the freezer is more than the circuit breaker will allow.
First try powering the freezer from some other socket on a different circuit (use a long cord), or unplug a few things that are nearby (in most houses, there will be several wall sockets on the same wire in each area of the house).
If the freezer runs fine from a different socket, or when you unplug some other stuff, then the problem is you are overloading the circuit you were originally trying to add it to.
If you can't get the freezer to run on any socket without tripping the circuit breaker then probably the freezer has an electrical fault and best you get a real electrician to check it (safety first!).
Oct 02, 2012 | Freezers
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Problem on Manitowoc Ice Maker Series 150
if the reed switch is not tripped at the end of the harvest cycle it will shut down. when ice drops it hits a cover with a magnet on the right bottom corner. the ice falling moves the magnet away from a switch and lets the sequence reset and start over.
Jun 12, 2009 | Beverage-Air 23.1 cu. ft. / 654 liter...
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
MAIN RCD CIRCUIT TRIPPING OUT
it may not be the freezer. ground fault recept. are known to go bad pretty regular. upplug freezer and see if it still trips. It doesn't take much to trip one, so look for something simple
Aug 18, 2008 | Freezers
GE 16.7 Upright Freezer
HI the heat on the outside of the cabinet is normal. the freezer is now working properly give it 24 hrs thanks.
Jul 17, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Maytag 14.8 cu. ft. / 419 liter Chest Freezer MQC1557AEW Logo
90 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
john h
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
