Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Water wont come out
The water and cleaning solution will not come out on my steam cleaner. I've checked the belt.
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Jun 01, 2008
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Cleaning brushes wont rotate
I understand how important the brushes are when cleaning.
You may want to the check the pump belt for breakage for the brush belt and pump belt work in conjunction with the pump.
If you're still experiencing difficulty, you may want to have your machine inspected at one of our Authorized Service Centers. Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 17, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My hoover steam vac has developed a musty smell. Any ideas to remove this odor?
i often use vinegar and water to clean my steam cleaners. I use a 3:1 ratio of 3parts water to 1part vinegar. using 8oz's as a part. hope this helps good luck. whoops btw use mixture to run through machine and soak dirty water tank in.
Mar 06, 2013 | Vacuums
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
    see the causes and fix it. God bless you
    stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
    You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
    Thanks for asking.
    Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Wont put down water to clean
    PUMP AND BELT NEEDS CHANGING ,,,,,BSC APPIANCES 07779933829
    Feb 27, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Bissell pro heat steam carpet cleaner, not releasing water.
    That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
    Bissell 7901 Belt and Manual
    Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Hoover steam cleaner wont pickup water
    in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
    Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
    57 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
