Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
When you turn on the heater it does not light. piolet light is on. if I conect the two post connected to thermostat the burner will light, I disconnect the two and it stays lighted. If I turn off the heat and then if I try to light with Theromstat it wont.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The problem then seems to be with the thermostat. If you have an ohm meter you can verify by attaching the ohm meter to the thermostat and turning it up if there is resistance when the thermostat is turned up then the thermostat is okay if the resistance is infinite then the thermostat is not working.
Posted on Oct 08, 2010
Why doesn't it light?
You find instructions on youtube.
Feb 03, 2016 | Procom ML300HGA Heater
My dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Oct 30, 2011 | Empire DV-35 Heater
Installed upgrade to water heater and piolet light lit fine. for a minute the flame turned yellow as condensation driped but when it stopped flame went back to blue.
New gas water heaters drip condensation the first time they are lit.
The dripping stops.
You should be fine.
Keep us posted.
You can add a comment and I will help further if needed.
Nov 03, 2010 | Whirlpool Water Heaters
I have a RUUD Furnance with a piolet light. There
If you have a pilot, then this is an older furnace. Most of them use a 2 wire thermostat. Allot of the new digital, programmable thermostats require a 3rd wire - a common to the thermostat. Allot of old furnaces do not have a common terminal on the furnace board. It can be done, but takes a good technician. The way around this is to use a digital, programmable thermostat that will operate on straight battery. It will be stated on the thermostat package, saying it will operate with a common wire from the furnace or with only the use of the batteries.
Then make sure that you hook up the 2 wires to the "R" terminal and one wire to the "W" terminal, it doesn't matter which thermostat wire goes to which terminal.
Note: If you have a air conditioner installed, it will be a different story.
Sincerely,
Good Luck,
Paul Gibson
Mar 31, 2010 | Heating & Cooling
The piolet light will not light. If I turn the
You may have a plugged orifice in the pilot tube assy. If you have any way of getting to the orifice with compressed air, and blow back, it may dislodge it, if it is plugged. If possible, carefully remove pilot tube at valve end first, so that if it is debris in there, it blows clean of the tube, so it won't clog again. Otherwise you'll have to remove complete assy. Another thing to try as well, is to shut valve off, loosen fitting at valve for pilot tube, AND MAKING SURE NO FLAME OR SPARK ANYWHERE IN THE AREA, take a spray bottle with dish soap and water mixed (bubble tester) and then spray at pilot fitting when it is loose, and push pilot, to see if any bubbles appear, indicating gas flow. If no flow there, then I'd get a new gas valve.
Jan 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My mr heater won't stay running
No pilot in this unit.
Check the thermocouple and its connections.
The thermocouple is the device that has the copper cable connecting it to the vave unit. It leads up into where the burner can "heat it up". This indicates to the controll valve that the gas is actually burning and keeps the valve open.
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
How flem sensor works in furness
After you hearthe click from the ignitor your piolet will light. the flame sensor (mounted next to the piolet (tip in the flame) ) will sence the heat from the piolet sending a milivolt siginal back to the ignation board. once the board knows there is a piolet and the system is safe the main valve will open igniting the burner trays.
Mar 16, 2009 | Goodman GMS90703BXA Heater
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
I have an old gas heater when i go to light it the piolet light wont stay on when i turn the knob to make it hotter.
Old heaters that have a "standing" pilot light that burns all of the time use a device called a thermocouple. The thermocouple sits in the flame of the pilot and when heated by the pilot, produces a very small amount of electricity (approx 30 mV) which the heater interperets as proof that the pilot is burning and indicating that it is okay to turn the main burner on. The thermocouple is a part that wears out and when it fails causes the exact problem that you are describing.
Jun 26, 2008 | DeLonghi Heating & Cooling
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
152 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
