Question about Gateway GT4016 Desktop PC
MY Gateway GT4016 Will not start anymore, i first replaced the power Suply and nothing happened. the fan runs and a light blinks then it shuts down again, i used to start it by just pressing the button and before it turns off again id hit it again so it jumpstarted it but that no longer works. Any ideas guys? im a techy so this is quite weird for me to be asking for computer help O_o.
  • 57 Answers
Make sure all fans are running power supply one to hehe Maybe a bad power button? I had a gateway that did some thing very close to that because the cpu fan was not turning and a hp that did that because the power supply fan was not turning. Thats where I would start then make sure the mem is seated good and not bad you know the drill ;) if you replaced the power supply with a factory replacment it should be a voltage or wattage problem. Might also try a hard boot the power plug take the cmos bat out hold the power button down for 20 or 30 secs some people say to leave the cmos bat out and try to fire it up. I know that works on some laptops but I always had better luck putting it back in for desktops cant hurt to try it. If you have two ram sticks in it pull the # 2 one and try to fire it up if nothing changes swap the # 2 one with # 1 leaveing slot 2 open and try it that will tell ya if it is a bad ram stick I dunno just my two cents hope it helps
Posted on Dec 14, 2013
4 Suggested Answers
  • 55 Answers
SOURCE: CANT FIND A PRICE FOR
http://mydirect-it.com/advanced_search_result.php?keywords=gateway+gt4016&osCsid=93be5727e5b779c1478aa02765e25ac2&x=0&y=0
Here a website for the GT4016. If you find this helpful please rate me
Posted on Nov 30, 2008
  • 173 Answers
SOURCE: gateway gt4016 won't boot. Fan runs but nothing
open cpu cabinet and pull Ram and refix it.
Aslo reattcha llconnection to mother bord.
Pull cmos cell for 15 minutes so all bios setings are set to defaults.
Posted on Jun 13, 2009
swoop611
  • 488 Answers
SOURCE: GT4016 hit pwr button comes on flashes three
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
Posted on Dec 02, 2009
New power supply & moherboard in pc, still turns on only halfway
UNPLUG IT AND RESET YOUR CMOS BATTERY THE TRY AGAIN. GOOD LUCK.
Oct 11, 2014 | Gateway GT4016 Desktop PC
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
My gateway GT4016 does not turn on, I brought it
if the unit has lights and fans running when you try to start it up the the mobo does need to be replaced. if there is no activity the the power supply has to be changed out. always get two opinions when dealing with pc repair shops to make sure your not getting scammed
May 12, 2010 | Gateway GT4016 Desktop PC
GT4016 starts up then clicks off and on off.
try to replace the MEMORY and all the Cable that connected to the MOtherboard..
Oct 23, 2009 | Gateway GT4016 Desktop PC
Gateway gt4016 won't boot. Fan runs but nothing
Jun 12, 2009 | Gateway GT4016 Desktop PC
Gateway gt4016 problem
Check your monitor on another computer. If it is ok connect it to your bad computer. Open the CPU case and unplug all the data cables and power cables to HDD, floppy and cd/dvd. Remove keyboard and mouse. also remove pci cards if any. You didn't mention about video card. I guess it is onboard. Now put it on an see. If nothing happens blame the motherboard.
Dec 17, 2008 | Gateway GT4016 Desktop PC
My gateway is not turning on!?
The most likely possibility is you need to replace the power supply. If you have a power supply tester you can check it. If not you may want to borrow or purchase a new one. They, for the most part, are not that expensive. I hope this helps. Joe
Nov 25, 2008 | Gateway GT4016 Desktop PC
Startup
Sounds like a new power supply needed...could be motherboard, but a power supply is $29 and a new motherboard could be up to $250 from GW. Good luck.
Aug 28, 2007 | Gateway GT4016 (6528) PC Desktop
Gateway GT4016 Desktop PC Logo
226 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
