Question about Nikon D90 Digital Camera with 18-105mm lens
Pictures are in black and white, how do I get back to pictures in color?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the info button (near the southeast corner of the LCD monitor on the back) twice. Use left/right on the multiselector to highlight "Set Picture Control" and press OK. Use up/down to make a choice other than Monochrome and press OK.
Posted on Oct 08, 2010
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Nikon D90 Digital Camera with 18-105mm lens Logo
21 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
