Question about GE (PSS26MSRSS) Side by Side Refrigerator
Have a 10 year old GE profile side by side refrigerator that has a puddle (2-3oz) of water about once or twice per week comming from back bottom. I have checked the drain in the freezer section about 1.5' up from the back and water flows to bottom evaporator pan. However, when I check pan other times it is dry. I can only see part of the evaporator pan when I take off fan blade so I am not sure if there is other items that flow to that pan or it that side under the frezer is filled with junk? Since GE does not provide system diagrams other than electrical it is not easy to trouble shoot. Coule use help. Jim
    Sergeant:
    Champion:
  • 351 Answers
Hi that the only drain going to the pan douse it have an ice maker if so check the water line going up the back to ice maker check around water valve may have a small hole or a hole in pan jim
Posted on Oct 08, 2010
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I HAVE A GE PROFILE TPH21PRS - ABOUT 10 YEARS OLD. THE WATER TK DIS IS CRACKED ALONG THE SEAM. IF I BUY A NEW PART, WHERE DOES THE WATER LINE CONNECT IN- I ASSUME THAT THE LINE WHICH ENTERS AND EXITS THE...
Yes and the replacement will be simple to replace and install. The part comes with new tubing and feed through the openings in floor and back of refrigerator. I will also be available to assist your installation per email or phone. Just let me know, Thanks, sea Breeze
Nov 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
