Question about Health & Beauty
Schwinn diagmostic lite on sometimes wont work could use a wiring diagram
    President:
  • 2,777 Answers
I can help you get this, what model scooter is this?
Tim
Posted on Oct 08, 2010
I have a 2001 neon the break lites do work could it be the body controll mod
https://s2.postimg.org/41u0q2p89/brake_lites.jpg
Click on the link.
Can you read wiring diagrams? If your saying brake lites don't work, are all brake lites out, I'm talking about the high mount and lower brake lites, both? If both are out have to check fuse, not only check fuse, use a test light and check voltage on fuse circuit. The high mount brake lite and lower brake lites are wired differently.
I want to add, if I'm looking at correct wiring diagram, the bcm is not involved.
Jul 29, 2017 | Cars & Trucks
Power winow wiring diagram for 2004 venture
https://s2.postimg.org/einm75w6x/power_windows.jpg
Click on the link.
Check the wire harness on hinge side of driver door. Probably has a protective rubber boot, see if you can pull boot back far enough to get at yellow wire, key on, use a test lite and probe yellow wire, see if there is voltage.
At the lower part of diagram, see black wire, terminal G, that is ground, find that in wire harness and check it. You can use a test lite connected to battery voltage, probe the black wire, if the lite comes on, at least the ground is good enough to turn on the test lite. Because you open and close the driver door so much, sometimes those wires break.
When probing any wires, cover the hole with fingernail polish or something, when your done.
Jul 21, 2017 | 2004 Chevrolet Venture Passanger
Wiring diagram for a Schwinn S180 electric scooter
Request the diagram directly from Schwinn.
Feb 06, 2017 | Schwinn Motorcycles
I require simple wiring diagrams for a 1976 F150 pickup.
Use a test lite on negative side of coil, engine cranking, the lite should pulse?
It appears the vehicle has electronic ignition, There is a separate ignition module. In the wiring diagram, I can't guarantee the wire colors. The older my wirings diagrams are, it seems, the less accurate they are. I hope it is readable, If no spark, I'd check the ignition system, Check fuses--fusible links--battery connections.
Oct 02, 2016 | Ford F-250 Cars & Trucks
E-1 massage on Schwinn Bio Dyne 150
1) adjust the speed sensor, clean it and tigh the wires connector see the diagram.
2) test the input voltage motor, if there are the motor need repair
3) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 27, 2012 | Schwinn 250 Recumbent Bike
Was given a Schwinn spin bike Model DX 900. Has electronic "counter" for miles, calories, etc., changed batteries and now won't work.
Sometimes taking them out looking at the Battery holder for corrosion first then check if the batteries are in the right way ( I've made that mistake ) Also the wire that leads down to the sensor and see if its adjusted correctly
Aug 12, 2010 | Schwinn 430 Elliptical Trainer
I need to assembly the wiring for the batteries. what is the method for connecting the 2 positive and 2 negative terminals?i have the schwinn S350 scooter.
Scooter positive terminal to battery 1 positive. Scooter negative to battery 2 negative. Battery 1 negative to battery 2 positive.
Jan 28, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
F150 tail lites will not come on when headlites come on
Check to see if the wiring isnt wrong. sometimes wires get crossed and the lights wont function properly. check each strand that they go where they belong.
Apr 11, 2009 | 1982 Ford F 150
Wiring diagram
i found wiring diagram for honda 50 through internet and i solved my problem. tnx for your support, more power
Jun 14, 2008 | Transport Schwinn Rechargeable Portable ...
Health & Beauty Logo
19 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
