Question about Kenmore 63942 Dryer
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
  • 2,418 Answers
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Posted on Oct 08, 2010
  • r_arreola5 Oct 08, 2010
    I have a gas dryer......
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
My dryer does not dry only make steem it does not dry the clothes
Check your vent (exhaust) system. What you are saying is what happens when the exhaust system is cloged or very restricted..You HAVE TO HAVE GOOD AIR CIRCULATION TO HELP REMOVE THE MOISTURE FROM THE CLOTHING otherwise all you end up with is warm moist clothing.. Test by starting unit and going outside to the exhaust vent and checking for a good warm flow of air.I suspect the whole system will need cleaned not just the flex hose behind unit Good luck
Aug 13, 2010 | Hoover Dryers
Estate dryer do's not dry fast anymoe
Couple of things to check, the blower fan assembly that is close to the lint filter, might be clogged or the exhaust duct hose might be too long and has too many bents, that restricts the air flow. check also outside for restrictions
Jan 06, 2010 | Estate Dryers
My dryer won't dry our clothes
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement. The element has a contact in the 'timer' circuit too.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 18, 2009 | Dryers
Very Hot Top
It appears that your venting system is restrictive to a point that the hot air coming from the exhaust of the dryer cannot get outside due to excessive lint in the line. If possible, can you use a flex line and temporarily vent it out thru a window until your hard-piped vent dries out and can be cleaned properly? These dryers have thermal overloads to shut them down if they get too hot but since you mentioned the heat was near the top in the back.. I would make sure the power cord connections are tight.. ( do this by unplugging the dryer from the wall receptacle) the open the access cover were the cord enters the back of the drier.. then use a screwdriver and and make sure all 3 or 4 wire terminals are tight. A poor or loose contact there is resistive and may get hot enough to cause a fire. Make sure to remove or disable power BEFORE servicing this area.. Hope this helps..
Aug 31, 2008 | LG DLE9577 Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Jan 02, 2008 | Dryers
Kenmore 63942 Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
