Question about Akai LCT2701TD Television
AKAI TV Flashing Red light
No simple solution.  Expert TV told me it was the mother board and would cost $$$$ over 300.  I opted not to spend that kind of money.
One guy online told me it was the power supply and if I took the power supply out of the TV and sent it to him, he could fix it for $70 plus S&H.  He lives in Canada.
Still looking and open for local suggestions
  • GIORSIL Jun 19, 2008
    i can't fin the part mlt166a i don't care how much is i need know where find this part please
GIORSIL
if you have a solution. please post in english.
Posted on Nov 07, 2008
Yo tengo ese problema y se lo que es es la fuente de poder (power Supply) porque se que es la fuente de poder facil tengo 2 tv lcd iguales y el que me *** problema la puse la fuente (power Supply) del otra que estaba bueno y problema resuelto, el problema es que esa fuente de poder (power Supply modelo MLT166A esta descontinuada. llamen a este lelefono y ellos se la consiguen 17279341800 Nno hablo ingles pero creo que es un servicio autorizado AKAI lo segundo es votar ese tv y no comprar nada hecho en China
Posted on Jun 19, 2008
SONY LED TV MODEL - KDL-40W900A .MOTHER BOARD IS DAMAGED. REPLACEMENT COST 8000-10000 INR. CAN ANY ONE SUGGEST IF REPAIRING MOTHER BOARD IS POSSIBLE?? AND WHERE IN MUMBAI ?ANY CONTACT DETAILS ...
Mother board repairing at component level is not possible to Sony. It is best to replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 02, 2016 | Sony Televison & Video
HI...WE HAVE A SONY PROJECTION TV, MODEL #KP 53 S 35, NO PICTURE NO SOUND, DARK SCREEN, JUST SMALL FLASHING RED LIGHT ON CONTROL PANEL (STANDBY LIGHT). NO POWER ON SOUND WHEN TURNED ON. TOLD WE NEED...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
Tv turns off red light flashes and i hear a chriping sound
This problems is also parts of tv convergence board have dead 2 STK convergence ICS and some or all the resistors dead too.This problems the 2 STK and some or all it resistors are completely dead that why u only have red flashing light and chirping sound only.If your tv have any life function left of the tv convergence board u would have only mis alignments of colors R,G,B lines,have colors shadows or 3D pictures look alike.The shop,will cost like $300-350 to get the tv convergence board fixed also fixed this problems too.
Jan 05, 2011 | Hitachi 53UWX10B 53" Rear Projection...
TV will not respond. Red power light indicator
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2010 | Akai LCT2070 20 in. EDTV-Ready LCD...
No picture
You may need to replace your Tvs convergence board. Go to www.partstore.com and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace. I just replaced my convergence board on my Akai, which had the same problem and it worked.
Dec 10, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Red light flashes and system not responding
Erratic power supply, at least hope its just that and not a burnt CPU thats keeping it from posting.
Sep 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Turns off 2-3 seconds after turning on-no red light?
sounds like a power deflection board issue its one board and it cost around 300 bucks its calld the d board i believe if it was just a cold joint solder it would be some xtra work trying to find the exact point but good luck
Jul 04, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Televison & Video Logo
376 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
