Question about Insignia IS-LCDTV32 32 in. Television
I have a 32LCD that will turn on intermittenly, so sometimes it works then other times it will not. bought it in Feb. 2007.
  • 11,361 Answers
Cheaply made TV.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 09, 2010
2005 Kia Amanti - something draining power from battery
just bought?? its 5 years old. have the battery tested before you change anything. also test voltage at rest. should be 12.6 volts and when running should be over 14 volts.
Dec 06, 2017 | 2005 Kia Amanti
2009 altima doesn't recognize key all the time
Nissan been having some problem with key FOB, they don't wont to acknowledge it cause it will turn into a RECALL expensive fix for them.
Sep 21, 2012 | 2009 Nissan Altima
My car key works intermittenly and sometimes not at all. I have a 2007 550i bmw
If it is not a remote problem, you might check and see if it is a chip in the key. Some models have them and you need a new key if the remote is not the problem. Dealer item only...
Jan 14, 2011 | 2007 BMW 550i Sedan
2007 JEEP GRAND CHEROKEE WON'T START , LIGHTS ON DASH AND RADIO COMES ON , BUT WON'T TURN OVER, READS TRANSMISSION HIGH TEMPERATURE , JUST BOUGHT A BRAND NEW BATTERY FOR IT
I have found the solution to this problem. I have replaced a total of 3 starter motors and has gone away for various periods of time. Further diagnosed when concern happened again starter
would work again after starter ignition feed wire wiggled. I found corrosion build up in connector at ignition feed wire. I replaced connector on wire to starter solenoid and concern has not returned.
Aug 31, 2010 | 2007 Jeep Grand Cherokee Overland
Insignia model ns-32lcd will not power on.
If you wish to get some details; visit the site linked here. Pull up older posts.
May 17, 2017 | Insignia IS-LCDTV32 32 in. Television
2001 s-10 Heater fan works intermittenly
Replace Fan or possibly thermostat module
Jul 08, 2017 | 1996 Chevrolet Blazer
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Microwave stopped heating
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Dec 01, 2007 | GE Monogram® ZMC1095BFBB /...
Insignia IS-LCDTV32 32 in. Television Logo
29 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
