Question about Canon FAXPHONE L80 Laser
My fax machine does not send or receive faxes any more. it has manuel in the window, i don't recall seeing this in my window before.
    Guru:
  • Canon Master
  • 452 Answers
It can be a problem of the parametr RX and Tx try to change velocity of tx and then Rx if the problem not solved you must change the NCU board
Posted on Oct 11, 2010
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
How do i receive the fax directly to the pc without the internet ?
From what you are saying. I believe you are trying to receive (or send) a Fax directly to your PC but NOT being connected to the Internet. That is...receive a fax on your telephone line.. This IS possible but you need what we had in the old days called a "Fax Modem" on a PC card to be installed in one of the spare slots inside your PC to which you plug your Telephone line..
Windows has ALWAYS had the feature but you need the Hardware Modem to do it'
See here on how to do it. http://windows.microsoft.com/en-us/windows7/products/features/windows-fax-and-scan
Sep 03, 2014 | Panasonic Uf-8300 Laser Fax Machine
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
I can't receive Fax on this printer a960 I can send but not receive
Here is the Manual for the printer
Product Support Dell US
You need to set up the printer as on page 49 to automatically print faxes.
Nov 07, 2011 | Dell A960 All-In-One InkJet Printer
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
Fax machine can send, but not receive. The line has been tested and is fine
You need to make sure that your fax machine's ability to receive an incoming fax has been enabled. Please read your manual and follow the instructions to enable receipt of faxes.
Don
Jan 29, 2010 | Brother MFC 9700 All-In-One Laser Printer
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Faxing
Make sure that you have settings to RECIEVE FAX.
Go to start on your Desktop. Click on All Programs. When window opens, click on accessories. When accessories window opens, click on COMMUNICATIONS. When the Communications window opens, click on Fax. When the Fax window opens, click on FAX CONSOLE. When the FAX CONSOLE window opens, click on RECEIVE FAX NOW.
You might have to wait until your telephone/fax machine, rings and then click RECEIVE FAX NOW if it does not work automatically.
The person who is sending you a Fax might have to inform you they are sending a Fax to you right now.
Hope this is helpful to you. Good luck.
Sep 30, 2007 | Lexmark X75 All-In-One InkJet Printer
Canon FAXPHONE L80 Laser Logo
122 people viewed this question
old marine
old marine
