Question about Samsung HCN653W 65" Rear Projection Television
No Picture - Sound
Picture went out and the timer light started blinking. I turned off the tv, unplugged from the power outlet turned on the tv until the power drained and the timer light went off. Plugged it back into the outlet and turned back on. You can hear the tv "turn on" beep. The sound comes on, but picture never comes up. Then timer light starts blinking again and there is no sounds. Does anyone have any ideas on what's causing the issue?
  • 3 more comments
  • Dave Graham May 31, 2008
    Gozar - Comment: Had an issue with convergence last year. Experts recommended replacing the convergence modules...which required soldering. I couldn't do that so I replaced the entire board they were on. The cost of the board was cheaper than ordering the modules and paying a professional to replace them. A board I can replace, but not individual parts on a board. Anyway, I have to old board still. Tried reinstalling the old part, BP95-00142P, to see if it was an issue (another site suggested replacing that part). I'm still having the same issue...my old convergence issue did not come back. In the interest of saving time, I did use all of the cords from the new one when I tested the old. So, unless it could be an issue with one of the cables, I don't think it's the amp module.
  • chef_brown07 Jun 02, 2008
    Same...Picture went out and the timer light started blinking. I turned off the tv, unplugged from the power outlet turned on the tv until the power drained and the timer light went off. Plugged it back into the outlet and turned back on. You can hear the tv turn on, but picture never comes up. Then timer light starts blinking again and there is no sounds. Does anyone have any ideas on what's causing the issue and how to fix?
  • Dave Graham Jun 06, 2008
    Had a repair man come out to look at my TV. The TV is powering up, sensing a problem and shutting back down...and then cycling through again. He tested the voltage on the circuitry through the back of the TV. Then, he took off the front of the TV and turned up something. A green horizontal line appeared on the screen, apparently there was supposed to be something vertical. Said the issue was with the Vertical Deflection...I did some research and turned up the term Vertical Collapse as well. He did some more work but could not resolve the issue today. Said it might take getting the TV to his shop to do further testing and investigation, said it very difficult to work on the TV in someone's home because of the layout and sensitivity of the circuits.
    He said worse case scenario was he would have to replace a board (sorry, I didn't write that down and can't recall now).
    He was going to do some more research into the issue to see if anyone has specific suggestions.
  • Karl Nitz Dec 16, 2008
    My HCN653W will power up, I get the power on tone and the screen comes up for about 3-5s, then it shuts off and the timer/power light blinks. I was also told it was an issue with "vertical resolution". I've made other TV repairs in the past (replacing convergence amplifier ICs, flybacks, etc.) - just looking if someone can identify which component is the culprit to replace for these symptoms. I'm also trying to identify a source for the schematic and service manual.
  • Anonymous May 02, 2009
    I have the samsung hcn653w and when I turn it on I get a grid of green lines.Is this a convergence problem only? and if so can I get away with just replacing the sub deflection board?
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
Posted on Aug 04, 2008
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
195 people viewed this question
Henry  Thomas
Henry Thomas
