Question about Sony VPLES1 Projector
Tengo un Video Beam sony VPL-es5 con 500 Horas y a hora dura prendido 30 segundos y se apaga que hago ? Tengo un Sony vpl-px10 se le cambio la lampra y segue diciendo que se le cambie que hago pra reinicierla ?
projdoc
  • 2237 Answers
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Posted on Dec 08, 2009
Testimonial: "Thanks very much for the help. "
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
SOURCE: Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2
hi your projector probaly has done around 2122 hrs on the bulb just reset the lamp timer and you should be good to go ps this worked for me (answer yes to replace bulb and clean filter then press ok pps might be a good idea to start saving up for a replacement bulb hope this helps cheers !!!
Posted on Feb 22, 2011
heathgr
  • 442 Answers
SOURCE: Sony VPL-EX3 "Lamp cover problem", it wont switch
There is a small switch that detects when the lamp cover is securely tightened down, so that it protects the user from the high voltages, hot surfaces, excessive bright light in the eyes, and damage to the face if the lamp implodes due to old age and overuse.
so check if the switch operates when a toothpick is pushed up and down in the cavity.This model suffers this problem when the cover is slightly warped with old age.
so put a strip of folded paper between the cover plastic protusion that actuates the switch and the switch and secure the cover and see if this is all that is needed to activate the switch properly.
if it now works, you can try putting a small drop of silastic on the cover protusion and wait till it sets over several hours in order to lengthen it slightly so that it reaches the switch properly
Posted on Jul 01, 2011
SOURCE: HOLA TENGO PROBLEMAS CON
tengo problema con mi proyector sony vpl-es4 me aparece una leyenda y me indica fuera de rango
Posted on Aug 28, 2012
Tengo un mercury tracer ls y mi problema es que cada que paro en un semaforo la aguja de las revoluciones empieza a vibrar y quiere apagarse, tengo que darle un golpe al aselerador para que suba la aguja...
losiento pero yo soy mechanico de europa (espa?a) ninguno gota de idea por esta coche americano .El unico contesta con mas probabilitad es un manguera fino connectado con el collector de entrada despuce passa por alguno valvula controlado el vapor ,cruise ir algo .
Jun 22, 2017 | Ford Explorer Cars & Trucks
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
Hola... quiesiera saber por que cuándo enchufo el router no encienden las luces?
puede que haya un falla con la fuente de poder, con la tarjeta madre o con la toma de corriente en donde se esta conectando el router.
intenta conectar el router en otra toma de corriente espera algunas horas y vuelve a intentar.. tengo un router dlink que a veces deja de prender y despues de algunas horas de estar desconectado al reconectarse vuelve a funcionar, no es normal pero pueda que la condicion o el fallo solo sea temporal
si el router tiene menos de 1 ano pide reemplazo bajo garantia.
Dec 20, 2010 | NetGear MR814 Wireless Router
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Enciende y aparece el logo de la bateria y luego se apaga , y por mas que lo haga cargas mas horas sigue igual . Por favor no se sin ayudar
Si cuando te aparece el logo de la bateria, esta tiene poca carga a pesar de haberla cargado durante horas, entonces podria ser:
1) Un da?o en el cargador (en este caso igual no funcionaria aunque tuvieras la laptop conectada directamente al tomacorriente). 2) Un da?o de la bateria (la bateria no esta tomando la carga). 3) Un da?o en la fuente de poder.
Tambien te recomiendo revisar que los contactos esten limpios: 1) Donde la bateria tiene partes metalicas que hacen contacto con otras partes metalicas de la PC. 2) Donde hacen contacto las partes metalicas del cargador con las partes metalicas de la laptop.
Asi podras saber si tienes que cambiar el cargador, la bateria o si tienes que llevar la PC a un taller a que le revisen la fuente.
Oct 19, 2010 | Computers & Internet
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
I need to repair a tv philips LO1.1UAC-7638
Check the Video amplifier IC on CRT board. I'm sorry I can't write in espanhol. Try. Good l
Dec 13, 2008 | Televison & Video
Un problema con webcam
como puedo hacer mi driver se me a extraviado como mi maquina tuve que formatearla ahora como hago para instalar mi wed cam
Jun 16, 2008 | Computers & Internet
Sony VPLES1 Projector Logo
785 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
