When i switch it on, my nokia 3230 keeps restarting and most of the times displays "insert sim" and "invalid sim".
Please help me. Thanks.
Paschal, Nigeria
Re: When i switch it on, my nokia 3230 keeps restarting...
It may be due to network lock, contact service provider , else you can get unlock codes here http://www.theunlockarena.com/ you need to specify the phone model and network provider
It may be due to network lock, you can unlock it and switch over to another network , you can get unlock codes here http://www.mobile-unlocker.com/nokia-3230/rs2wp9/ you need to specify the country and network provider
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
1 - Switch on your Nokia 3230 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3230.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3230 would then display the message "SIM Restriction
Off" and will be unlocked!
The letter p
appears if you press the button star(*) three times quickly
The letter w appears if you
press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE (2630111022) you need to enter is
the unique unlock code for your Nokia 3230
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
Hi Friend, Initially u have remove the sim card and the battery. Once u have removed insert only the battery and put to charge for 10 to 15 mins. then remove the mobile from charger and insert the sim card. Now after 30 sec switch it on.U will be able to do the process
please try that sim in another mobile if it still get error message then that means ur simcard is faulty. but if that work fine in another then that means your 3230 is faulty and you have to format that.
format with following code: *#7370#
after that it will ask for another code then insert 12345, your mobile get formatted now.
keep in mind that your all data on phone memory of that mobile get lost, if you that.
if nothin get right for you then you have to go nokia service centre at last.
