Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer Yes I hear a click when I open and close the lid, should I still do the rest of what you said? My brother, who is not a repairman, he said, it might be the timer, or the starter, or the dial????
    Genius:
  • 1,122 Answers
Could be timer,or motor short out,check and wire connections,remove time and look to see if you have any burnt point,hope this helps .
Posted on Jun 03, 2008
Maytag bravos mvwx500xw0 has no power after closing lid
You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
Jan 12, 2013 | Maytag MVWX500XL High-Efficiency Bravos X...
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
Will not drain
check the lid switch,close the lid,open it a few inches and close it down,you should hear a clicking sound no click bad lid switch
Mar 18, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer stopped dead in mid load.
Check the lid switch. You should hear it click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 18, 2011 | Kenmore 24032\24036 Top Load Washer
Washer will not drain, full of water.....what do I do?
next time send the model number,you could have a bad or blocked pump or a broken lid switch,close the lid and open it a few inches open and close it a few times you should hear a clicking sound,no click bad lid switch depending on the model.
Sep 25, 2011 | Kenmore Washing Machines
I have a top loading whirlpool washer. For some reason it stopped spinning. The water is coming in and draining I can hear the motor running but it wont spin. Any suggestions of how I can fix it without...
it sounds like the drive cupler or also known as motor cupler,,,tilt unit back and look underneath washer,,recomendid to have someone hold it so it wont fall forward on you,,then look for a plastic and rubber oreo cookie that is the cupler,,located between motor and transmission,,,second issue and a bit easyer door lid switch or safty switch,,lift cover and slowly close if you hear a click it is ok no click means no good,,,it shold click at the closed point,,if not unit beleaves door lid is always open and will not spin,,,also if unit aditates but no spin it is normally the door swich as well www.myabcspace.com/washerwizzards
May 17, 2010 | Washing Machines
Ultimate Care II, delicate cycle fills nothing else
sonds like the door lid swich is not activating properly, next time it does not star for you try lifting the lid and listening for a clicking noise upon closing it.. i bet yo ucant hear it, if this is the case look to the left side of the door and make sure the hinge scres are tight, and if so you can liftthe lid( and with your hand under the lid open and clos a feww times ( you wantto feel the pin that actuates the switch its actualla contiuation ofthe hinge itself, when oyu locate it you can try to bend it towards teh back of the unit.. i use a hollow nutdriver/screwdriver to accomplish this, as you push it the lid will wantto close( your pushing against it) afeter yo udo this you should hear it "click" easier when opening and closing
Mar 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Washing Machines
Washer will not start
It sounds like the lid switch may be bad or have come loose. Open the lid and there should be a thing on the underside that pokes into the washer when you close it. At the place where it pokes into the washer you should see the top of the lid switch and it should be flush with the washer body. Stick a screwdriver into that hole to push down the switch and it should click. Pull the screwdriver out and it should click again. If it does click then close the lid slowly and listen closely near the switch to see if you still hear the clicking.
If you don't hear the clicking, then you will have to change the lid switch (usually costs about 30-50 dollars) or just bypass it. If you do bypass it, be careful. It will still spin even with the lid open and can be dangerous.
Dec 05, 2007 | Roper RAX4232KQ Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
