Question about Canon PowerShot S2 IS Digital Camera
When i look thru the camera there is no scene just black
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras, but especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Oct 08, 2010
Cannot get into portrait mode
You could be more specific about the issue:
  • What modes does it let you choose?
  • What happens when you press the scene button
The default scene mode is portrait mode.
You could consult the user manual at:
http://download3.nikonimglib.com/archive1/MYuI600nA8Zp00p3vNT88HY5EH77/S6800RM_(En)01F2.pdf
Page 34 shows how to change the scene modes, The technical notes contain further troubleshooting instructions.
Jan 28, 2015 | Nikon COOLPIX S6800 Digital Camera Black
My polaroid iS2132 won't change settings when I turn the mode dial/Can't set the intelligent scene mode.
When you put the Mode dail to the SCN mode, It will enter the last used Scene mode. THEN press the MENU button to select other scene mode.
Don't turn any dail. Use the navigation controls left and right from the OK button, to move through the section. Press OK button to save and activate the selected scene mode.
Success
Nov 17, 2013 | Polaroid IS2132-BLACK 16MP 21X Zoom...
How can I shoot in black and white from my P300 (Nikon) Camera?
You can use the Black and White Copy scene mode or the Nostalgic Sepia or High Contrast Monochrome modes in the Special Effects scene mode. Refer to the appropriate sections in the manual for full details.
Mar 03, 2012 | Cameras
What should exposure compensation be set on
That depends on what you're taking a picture of. Normally, you'd want it on zero.
Use it if the exposure meter produces an exposure too light or too dark for the subject. The camera's meter is designed to render all scenes as a medium gray. If you take a picture of a white dog playing in the snow, the camera will try to render the scene as a medium gray. In this situation you want to use positive exposure compensation to render the scene brighter.
Conversely, if take a picture of a black cat sunning itself on a black car, the camera will again try to render the scene as a medium gray. In this case you want negative exposure compensation to darken the scene.
Jul 09, 2011 | Kodak EasyShare C143 Digital Camera
CAN YOU PLEASE EXPLAIN TO TO ME WHAT IS EV COMPENSATION AND HOW DOES IT WORK
EV compensation is "Exposure Value compensation". The camera contains an exposure meter which determines how much light is on the scene and sets the exposure appropriately. However, this meter does not know WHAT you're taking a picture of, nor does it know what effect you're going for. The best it can do is to assume you're taking a picture of an "average" scene and want it to be of "average" brightness. It does this by assuming the scene is "middle gray," halfway between black and white. Most of the time this works fine, because most scenes are, well, average.
However, this is not always the case. Suppose you're taking a picture of a white dog playing in the snow. Almost everything in the scene is bright white, but the camera doesn't know that. It tries to make the scene middle gray, and the result is that you get a gray dog playing in gray snow.
On the other hand, suppose you're taking a picture of a black cat sleeping on the hood of a black car. Here everything is black, but the camera doesn't know it. It tries to make an average scene, resulting in a gray cat sleeping on a gray car.
EV compensation allows you to override the camera's exposure setting. In the first example, you'd want to add two or three stops (positive EV compensation) to force the camera to render the dog and snow as white instead of gray. In the second example, you'd want to subtract a stop or two (negative EV compensation) to render the cat black instead of gray.
How much EV compensation is correct? Well, that depends on the scene. With a digital camera, you can look at the picture and see whether the dog looks white or the cat looks black. Film photographers take lots of shot, using various levels of EV compensation, so that one of them would come out right.
Mar 19, 2011 | DXG Technology DXG-505V Digital Camera
Hi - i have a Lumix DMC-LX2 that has just recently stopped operation - (for example) when set to (scene) the screen simply scrolls repeatedly thru the scene choices non-stop. When taken out of scene mode...
sounds like the button or direction joystick is making continuous contact. You could try using canned air on it to blow it out. Otherwise i would get it professionally cleaned. Nice camera by the way.
Aug 08, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
Can't save individual scenes as separate mpg files
Instead of using the camera suite... download your video from your camcorder directly to your PC in a folder (video's). there you will see each individual file (scene) that you took that day instead of one large scene. Then you can download/edit whatever scene you want into movie maker or just copy a sene right to a dvd
Dec 21, 2008 | Panasonic SDR-H40 HDD Camcorder
My Casio Exilim works fine, except on the screen it only shows black and even when the flash goes off nothing appears.
try putting it on scene menu this is common you can set scene to wat kind of environment your in
Nov 25, 2008 | Cameras
Black scene frame
i think you have changed the screen into other mode so that you are unable to see the recording picture there will be a switch to change the mode at the back of the cam or at the right of the cam.
Mar 25, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Digital camera UDC-5m - Uniden
you have to go down to the scene button when u are on the photo taking scene. then go up to auto the first one, and it shouyld be fixed :)
-berr
Dec 22, 2007 | Uniden UDC5M Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
