Question about Maytag Dryers
DRYER GOES ON, BUT THEN SHUTS OFF - Maytag Dryers
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. You can check it for continuity between its two pins with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
GE dryer dcvh680ej0ms runs 3 minutes and shuts off and resets time
On esimple thing to try is clean the dryer moisture sensing bars inside the dryer. Wet clothes rub against these bars and tell the control the clothes is still damp. IF no moisture is detected then she shuts down. So what goes wrong? Dryer sheets have a waxy buildup on them which tends to coat the bars. Moisture cannot penetrate the barrier and therefore the control thinks all is kosher and shuts down. Energy saver feature don't ya know. LOL Rocket scientists no longer have a space shuttle program so they engineering dryers now. LOL
Houston we have a problem.
Aug 03, 2012 | GE Dryers
DRYER NOT HEATING GOES ON THEN HEAT SHUTS OFF
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Whirlpool Dryers
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Dryer runs for about 5 minutes and shuts off.
You may have a faulty motor winding or run capacitor.If the motor wind is shorted it will get hot and the thermal cutout goes open circuit (inside motor)and it starts again when cool.Also check that the air flow is OK eg Some models have a separate fan belt.Hope this helps.Cheers.
Jul 28, 2009 | Whirlpool Dryers
Kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Mar 27, 2009 | Kenmore Dryers
Kenmore dryer goes on initially, shuts off and
Replace the gas valve coils.
They are not opening after they get hot.
Mar 03, 2009 | Kenmore 72722 Gas Dryer
Dryers Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
