Question about Jl Audio 1000/1 Car Audio Amplifier
Jl audio i have a jl 1000 mono when i turn the bass up the amp cuts off showing low voltage the amp was really hot i have had my stereo all the way up before never had this happen all the wires are good when i look at the cap when the amp cuts off its showing about 8.2 volts
    Problem Solver:
  • 6 Answers
I doubt that your factory alt can even think of keeping up with the 1000. it will draw up to 75 amps itself. just getting a cap wont help if your alt cant recharge the battery and the cap. it wont matter if you have 2 batteries and a 20 farad cap. best bet is to upgrade your alt to at least a 150 amp or higher. dont forget about the grounds and power wire upgrade too.
Posted on Jul 04, 2008
It sounds like your draining the cap to fast either try a 10 or 20 farad capacitor or a second battery even both i have a 1000/1 and a 300/4 with two 1 farad caps and the amps still make my lights dim and feel the altenater working when the bass hits. also check the gound wire and make surethe wire is metal to wire for a good ground it should help good luck man!
Posted on Jun 12, 2008
  • 631 Answers
If the amp was hot, it probably has a serious problem. You should have it checked out by a qualified tech. Don't continue to use it. More serious damage could occur.
Posted on Jun 01, 2008
  • Lionel Howe
    Lionel Howe Feb 08, 2014
    Thanks Man. My amp is actually staying cool. Hey, check this out... When I have my headlights on the amp doesn't cut out as often, and I can actually run the stereo at higher volumes. But, yeah, my lights definately dim... big time.
I have a jl audio 1000/1 v1 amp pushing 2 15"
add more batteries to the truck and up grade the alternator and fuse
Jun 06, 2013 | Car Audio & Video
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
How can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Sep 12, 2009 | Jl Audio 12W3 Car Subwoofer
My amp cuts off when i turn it up
do you have the amp knobs cranked?? gain and freq
May 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Low ohm p/l
Quick primer here... Impedance drops with frequency,
you might have the amp loaded at what seems a rated spec.
However if your bassing too hard the voice coil can leave the gap (magnetic Field) and drop your impedance far enough to activate the protect circuit. This usually occurs in a bridged amp.
You can always give JL ( John and Larry actually) a call.They are a outstanding Company to deal with.
Is Maynard still with them ???
Sumthin
Jun 04, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Power issue
Hello highs31 Ok this is a common problem and the fix is quite easy. even though you may not want to hear it. Here it goes: Your amplifier is drawing more current then your alternator can put out and more then your voltage regulator can control. This means that you must and I repeat must add another battery, alternator, and voltage regulator for your sound system. adding these components will eliminate your problems. That is the long and the short of it. I hope this helps, Thank you, Shuttle83
Oct 09, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Help
JL amps are somewhat sensitive to low voltage. Everything has to be perfect in the power supply feeding the amp. I'll assume that you have large enough wire. Check the owner's manual on the JL site. They likely recommend 4g or larger. You need to measure the voltage across the B+ and ground terminals of the amp. If it's dropping below ~11v when you turn the volume up, you need to determine why. Make the same measurements at the battery terminals. If there is significantly less voltage drop there when the volume is increased, check all of the points in the circuit where there could be a bad connection. Look for corrosion, over-heated connection on fuses or at the battery and make sure the fuse is in good physical condition. Some types tend to overheat and melt. If everything looks OK, begin measuring the voltage at each point where there is any sort of connector. If for example, you get a significant difference in the voltage on each side of the fuse, the fuse, the holder or the connections to the holder may be defective.
Oct 04, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
365 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
