Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
Vertical hold is always giving problem. it just switches off. then sometimes comes ON. I removed the revolving base & put it on flat table & it works. Dono where is the problem can you guide me where to get its schematics? Thanks.
    President:
  • 2,992 Answers
From what you say about the set working when it's flat on the table, I would say you just have bad solder connections on the board. When the set is flat on the table, the board isn't being flexed as much and the connections are working.
A schematic isn't much help in a case like this. A good light, sharp eyes and probably a magnifying glass is what you need. Tap gently on the board while the set is on and see where the trouble area is. (Obviously you will use something non-metallic...I use a bamboo chopstick.)
When you find the area most sensitive to tapping, examine all the solder connections and resolder any that look questionable. Be especially wary of anything mounted on a heatsink. Sony sets have had many models where connections on power transistors caused many problems.
Good luck, and thanks for using Fixya!
Posted on Oct 08, 2010
How do I get the blade on my new Black and Decker 15 amp table saw to be at 90 degrees? I have the angle device at the zero mark and the blade is still at a slight angle. Is there any adjustment tha
I had a similar problem with my Ryobi table saw. I got out my square to establish true vertical, then tapped the motor housing lightly with a rubber mallet until the blade was at true vertical.
(sometime a hammer is the appropriate tool.....)
Oct 10, 2014 | Black & Decker BDTS200 15-Amp Table Saw...
BT Aura 1500 Quad telephone - calls list freezing
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Jan 15, 2013 | Lands Phones
Turntable stopped revolving
could be the turntable motor itself,or maybe your microwave may have an isolator on the control board, if not to get access you need to tip the unit on its side so you can get to the bottom of the unit, (take the plate out first )you will see the access panel in the middle on the base of the uni,t it will have3 or 4 moutings that will need to be cut away then the panel falls off, you will find 1 or 2 screws holding the motor in remove the motor you need to take the part to shop where you will have identify the par,t there so many motors for microwaves speed shaft size and shape they may even test the motor for you,if its not that then best to take to a repair agen,t
Dec 11, 2012 | Microwave Ovens
I cant get the material feeder to come up so that the material can slide
Make sure feed dogs (teeth in needle plate beneath needle) are showing. Flip switch to UP position to "feed" fabric. Sometimes control fir this located on back of machine lower left side and " hidden" by your extension table, so remove that table and you'll find the switch! Jimmy
Apr 07, 2012 | Singer 3116 Simple
I need to replace my table top stand for mySony 32 inch Model # KDL 32S3000, can you guide me in the right direction
The instructions are in your USER MANUAL found at the following link:
http://www.docs.sony.com/release/KDL32SL130.pdf
In general though you should lay the tv screen side down on something VERY soft and flat like a bed so that the screen doesn't get scratched at all.
Then find the 3 philips head screws that hold the base to the tv. They should have replaced into the proper holes in the back of the tv when the base was removed initially. Unscrew and remove them and then place the base into position on the tv.
Once the base is fitted into position, insert and tighten the 3 screws again. The tv can now be lifted vertical again and placed where desired. Be sure not to press too hard on the actual LCD screen part when handling.
Good luck and post back how you make out.
Jan 23, 2011 | Televison & Video
My sharp R-953 turn table turns slowly when you put some thing on it ,it stops turning
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 13, 2011 | Sharp R-1870 Convection/Microwave Oven
How to remove a blade from a 2.5 hp sears table 10 inch tablesaw
First and foremost unplug the unit from the receptacle. Raise the blade as high as it will go and have it set to 0 degrees in a vertical position. Remove the throat plate (usually red) so you can access the bolt holding the blade in place. The saw came with a wrench for this purpose. It may have even come with 2 wrenches. One to remove the bolt holding the blade on and another to place behind the blade on the shaft to hold the motor. If it only has one wrench look for a small hole in the blade and use a screwdriver to keep the blade from turning. If there is no tool or hole to hold the blade then use a heavy scrap piece of wood to hold the blade while you remove the bolt. As you remove the blade notice the direction the teeth are pointing and put the new blade on turning in the same direction. You just reverse the procedure to put the new blade on. NOTE: Some saws have a motor lock that locks the motor and blade in position making it easier to change the blade. Just be very careful as it is easy to cut yourself on the blade.
Jan 10, 2010 | Craftsman 10" Table Saw
The motor is running but the drum is not revolving
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Jan 04, 2010 | Dryers
Light comes on, trun table revolves, does not heat
the magnetron might be defective, also check the door interlock switches, they cause a variety of problems.
Jun 28, 2009 | LG LRM1250 Microwave Oven
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
