Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
How to remove program wavelink ( Telnet ) in symbol MC9090G ?
How do I reinstall windows mobile 5 on my Motorola MC9090G?
Jose-
I would recommend you contact Motorola Solutions Support
portal motorolasolutions com
Mark
Motorola Mobility Support
Aug 27, 2014 | Zebra Symbol Technologies MC909X-G Series...
Hi, I need to set up telnet on a motorola mc9090, where can I get a manual that explains how to do it. It wouls also be of help if I could find out what the default set up passwords were on the unit. Chris
I have a manual for both the unit and telne application from Wavelink I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Jan 19, 2010 | Symbol MC9090 WIRELESS GUN TERMINAL ...
We have the PDT 6846 scanners for our warehouse and I am needing to know that configuration password is? Thanks
default passwords for these guns are:-
symbol
Symbol
system
System
case sensitive.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Oct 20, 2009 | Symbol PDT 6846 Portable Terminal
MC9090 being used outside in sunny conditions
If you are using Wavelink TE you can set the screen to different colours. That may help.
or TEL 01202 620955
Sep 29, 2009 | Symbol MC9090 Barcode Scanner
Connect PDT6846 to Wavelink COM Server
you can get it from www.wavelink.com they are quite good and still offer the files for the older terminals. however, you may need to get a license from them in order to use it on the pdt.
Jun 05, 2009 | Symbol PDT 6846 Portable Terminal
Symbol PDT 8100 and I2of5 barcode reading problems
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Feb 09, 2009 | Symbol MC9090 Barcode Scanner
Cannot read symbologie/BarCode: i25(interleaved 2 of 5) from an MC9090-G running VT100 emulation. How do I configure the scanner within Telnet-CE/Wavelink?? Thanks. Dante Barboza
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Jan 06, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Wavelink update 5.1 to 7.1
the prelicensing that comes with the symbol units is only for version 5, to upgrade you need to buy a license. its part of the marketing
Nov 02, 2007 | Symbol MC3090 Mobile Computer
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
681 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
