What key do I press during startup to get command prompt before windows loads?
  • 4,281 Answers
When you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu choose "Safe mode with command prompt" if your windows system files are working fine then you can enter in safe mode with command prompt. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 08, 2010
  • 2,418 Answers
During boot up press F8 a few times. This will give you a safe mode menu to boot in to windows normal or with network or a command prompt.
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
After downloading updates my paptop will not configure windows
Try this:
Windows XP
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
    Windows 7:
    1. Start your computer in safe mode with command prompt. For more information, see Start your computer in safe mode.
    2. At the command prompt, type rstrui.exe, and then press ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b_41.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Aug 19, 2012 | Sylvania G-Netbook
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
I hope that this helps you to sort out the problem. Toni
May 27, 2012 | HP Computers & Internet
My computer wont boot pass the windows xp screen. I can't get my system to go to my desktop. I can't work from any protocol to go into the internet. I'm thinking a factory rest might help
Restore windows XP in safe mode:
a Command prompt.
Use system utility tool like RegInOut to repair corrupt registry and windows files.
Jan 04, 2012 | Acer Aspire One AOD250-1326 Netbook
XP Home Boot Problem
Restore Computer:
  • Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  • Use the arrow keys to select the Safe mode with a Command prompt option.
  • If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  • Log on as an administrator or with an account that has administrator credentials.
  • At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  • Follow the instructions that appear on the screen to restore your computer to a functional state.
  • After restoring. restart your computer and use system utility tool like Reginout to fix coorupt windows files.
Dec 27, 2011 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
I have an Acer Aspire One AOD250 that will not load windows xp normally. It will only load in safe mode. When I turn on the computer it just hangs on the Windows XP page. What can I do?
Boot into Safe Mode with Command Prompt (F8 during startup)
run this command once it's loaded: chkdsk /r
Let me know what happens after normal startup again.
Oct 28, 2010 | Acer Computers & Internet
My window xp doesn't get restore ?
The System Restore feature will work only if the Windows System Restore feature is enabled.
The System Restore should work from SafeMode
Jun 30, 2010 | Acer Aspire One D2501413 Notebook
WINDOWS WONT START UP ON MY HP 8510P NOTEBOOK. ITS LIKE ITS IN SOME KIND OF LOOP. WHAT CAN I DO?
Try puttint in the startup disk if you have itn and boot from the cd drive. do not format, do a startup repair and it should fix the problem, rate please
Aug 16, 2009 | HP Business Notebook 8510p - Intel...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
