Question about Pool & Spa
I unhooked my timer to replace with a new one and dont remember which wires go where?
  • 990 Answers
If this is an intermatic timer (yellow dial) the wires coming from the power go on the first and third terminal. The two going to the pump go on the second and fourth terminals. If this has a black and silver dial the line from the power box go on the first and fourth terminals and the load going to the pump go to the second and third terminals. These are for 220v clocks, for 110v clocks you will need to check the instructions that come with the new clock.
Posted on Oct 09, 2010
I'm trying to replace the timer on my hotpoint tumble dryer an I can't remember were all 10 wires go please help
It's always best to leave the old timer connected, then get the new one and move the wires one at a time from the old timer to the new. If you didn't do that.....
I don't have your model number - if you look for that - on the door or the back - maybe we can point you to the diagram. Let us know.
Sep 17, 2016 | Hotpoint Dryers
I am replacing a intermatic t101r with a tightwatt timer. the t101r has 5 terminals wired, the tightwatt only has 4
Hello Barbara.
You dont have T101R timer. Because T101 has 3 terminals.
Remember any Intermatic timer can be replaced into the T101 enclosure.
First step, Identify your voltage.
Second step, identify if you are controlling a 2-speed pump.
Third step, identify the Intermatic timer by looking at clock motor and wiring.
T101R timer has 3 terminals, and has WG1570 120Volt clock motor.
T103R timer has 5 terminals and WH1570 120Volt clock motor
T104 timer and T106R timer have 5 terminals and WG1573 240Volt clock motor
Copy following link to help identify your specific wiring.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Terminal A on Intermatic could be Neutral or Hot depending on what has been done to alter the timer.
Generally the tightwatt timer wires very similar to P1353 timer.
http://waterheatertimer.org/images/P1353ME-2-speed-motor-500.jpg
Jul 02, 2012 | Intermatic Hardware & Accessories
It is a Ruud UAKA-024JA2 combination of air conditioner and central heater. The outside air conditioner fan stopped running but buzzed. The capacitor is out of order. Do you have instructions how to locate...
Hello, the capacitor is a round or oval metal can that is located in the control pnael of the outside unit. In order to replace it you must turn off power to you unit and unhook the wires that go into the capacitor, but make sure you label them so you remember where they go back. When you unhook the wires take a screw driver with a insulated handle and put in across the terminals of the capacitor to discharge it. Then just remove and install new one.
Aug 24, 2011 | Heating & Cooling
The timer isn't working. It still drys, will run constantly though. Timer does't move from any position.
Your timer sounds like it is defective and must be replaced, timers cannot not be rebuilt.
Be careful and make sure you get the same mfg. of the timer, or be able to follow electrical schematics
When you replace the wiring on the timer, be sure to only unhook and rehook up one wire at a time so you do not get the wiring mixed up and more create more problems.
Please rate me
Dec 06, 2010 | Kenmore 500 6952 Dryer
My dryer runs but wont heat up. The black wire on the motor was black so I put a new end on it but still won't heat up. I know the thermostats are good and the heating element is good so I am pretty...
ohm the motor out you should have resistance on the motor if it shows infinity you got a bad winding in the motor. The timer can also be ohmed out. should have resistance. unhook the timer before you ohm it also unhook the motor.
Jul 01, 2010 | GE DBSR453EBWW Electric Dryer
How to change the alternator in a 1995 Grand am Thanks
First unhook battery. Then unplug connectors and wire. Loosen bolts to take tension off of belt. Remove belt remove bolts holding alt. Place new alt in spot remember wich holes go where so not upside down replace bolts dont tighten yet. Install belt on all pulleys tighten tensioner bolt on alt bracket to snug tension after proper tension is achieved tighten all bolts and nuts. replace all plugs and wires reconnect battery pay attention to pos and neg dont hook up battery backwards. Congrats your done.
May 03, 2010 | 1995 Pontiac Grand Am
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Starter went out
there are 2 bolts that hold the starter on and three wires that are attached to the starter that have to come off. please remember to unhook the pos battery cable so you dont short anything out on the car it takes ablout a half hour or so to change the starter out and is pretty easy once you get it off. putting the new one back on is a breeze..
Feb 09, 2009 | 1996 Nissan Maxima
Ground Wire Hook-up
MTX has the hookup diagram here: http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/RTP251D_InstallSheet.pdf If you have the original wiring harness, the ground wire is normally black. The amplifier case or chassis is ground connnected on amps I've seen as well.
Aug 06, 2007 | MTX Thunder 251D Car Audio Amplifier
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
