Question about Kitchen Ranges
GE Profile mod JSP40A W3AA electronic panel has 8888888. What to do?
3 Suggested Answers
The_lRipper
  • 116 Answers
SOURCE: I have a 2004 GE Profile Washer with an electronic
Sorry for the trouble if this doesn't fix it you will have to replace the control board first make sure the unit is unplugged then next you will have to remove the dash there are 4 screws at the top of it they will be a Phillips head bit or a star or hex head remove those then slide the dash down. Next remove all the wires that are plugged into the board be careful so you don't break a pin and once that is done let it sit for 10 minutes then plug all wires back into the board and don't worry about getting wires plugged into the wrong ports it cant happen there all different and once that is done slide the dash back into place and plug it in and see if this fixes it if it doesn't you will need to replace the main bored hope this helps and thank you for using FixYa!
Posted on Jan 27, 2011
jijogeorgeku
SOURCE: GE Profile PT916SM3SS Control Panel gets hot
what is the E4 error ?
Posted on Nov 20, 2013
Testimonial: "I don't get an error code, it just gets very hot. This happened after running the self cleaning."
GE Profile Spectra F 0
Hi
Thanks for using FixYa. Error code F0 indicates failed thermistor/transistor in control. To resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 27, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
Where is the E.R.C. located on my GE Profile Mod. JS986SOF4SS?
it would be the big control board in the midde of your control panel...with all do respect if you have to ask where it is, you really should not be attempting to fix it.
I would contact a professional.
good luck
Jan 20, 2010 | GE Kitchen Ranges
GE profile XL44 code F7 & FO readng on
Turn the circuit breaker off at the switchboard for a minute then back on again. This may reset the electronics.
Nov 22, 2009 | GE Kitchen Ranges
Electronic Panel not working.
could have a bad board they are expensive,you might want to call someone in to do this ge is having alot of problems with them
Nov 02, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Aug 19, 2009 | GE Profile WPSR3100W
GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
I need the Manual for cordless phone with electronic secretary Mod. GE 26998
Here si the link to get the US telelphone user's manauals - I don't see your exact model # here, but if you change your country to your country of residence, they should have it:
http://www.home-electronics.net/ge/pc/user-manuals.asp
Sep 05, 2008 | GE 26998GE1 Cordless Phone
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
