Question about Sterling 402315-0 White Windham Two-Piece Elongated Toilet 402315
We just installed this toliet yesterday and there was nothing in the instructions about how to set the water level, there is not enough water in the tank to flush the toliet properly
  • 29 Answers
Depending on the type of water regulator/flush valve you have it varies. Usually there is a screw that regulates how much travel there is on the arm with the float on the end, or the float that moves up and down on the column. If you restrict this movement the water fills less and vice versa.
Posted on Oct 08, 2010
Would a vent problem cause the water to back up in the tub and cause the toliet to bubble?
A vent would cause an odor problem but not a back up problem. There should be a clean out between the house and septic tank, if it is full the blockage is down the line, if its dry the blockage is in the house.
Nov 20, 2012 | Dishwashers
Bought a american standard toilet tank to replace our leaky tank. after installation and turned on the water, but the tank is filling very slowly. what could be wrong?
Actually sounds like trash in the toliet water valve.....or possible that if teflon tape was used to seal threads has been drapped accross inlet threads and caused blockage......Best way to check this is to take supply line loose from toliet and slowly turn water on while pointing the supply into a bucket or something to catch the water and see if the pressure is ok......Then check valve to see if grit or blockage is in the toliet valve.........Depends on valve design to whether or not you will be able to clean....may have to replace toliet valve with new one......hope this helps
Sep 05, 2011 | American Standard Home
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I...
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Nov 10, 2010 | American Standard 2002.800.021 Champion...
When flushed, not enough water coming from bowl rim holes to wash waste off sides of bowl. Have checked holes around top rim, none are plugged. This has been a problem since purchased one year ago.
Its simple. Check to see if you installed toliet right by removing top of tank and holding handle all the way down. Did it flush from all rim holes? If not, then u will need to get a garden hose with a sprayer to increase pressure and shot high volocity water at rim holes to unblock it. Remember the very front on newer blows do not have holes its a pee shield. Also try doing these other things adjust screw inside tank to make sure the bowl has enough water in it to do a good job. Check the rubber tube going into the hollow pipe and make sure it is going fully inside the plastic pipe that is sticking out of the top of the water in the tank. Also you need to have enough water in tank to allow it to flush good. To increase tank water levels then just unscrew the big plastic ball (or just bend wire to allow more water or bend to allow less water) at top of water in tank. Also increase (max) water pressure at wall to allow it to work at its best. If you have hard water it can cause problems but you say it happened even new, so, you do not have to go in that direction.
Oct 06, 2010 | Kohler K-3497 Cimarron Comfort Height...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
Soemtime i go to the bathroom and nothing cums out??! HELP!!
mcdevito75 here, Increase your green vegetables anf drink water 3--6 pints of water a day. Things will happen naturally.
Jun 26, 2010 | Gatco Toliet Paper Holder by Inc
Toto toilet has weak flush
Check water level in tank and also under rim off toliet bowl where water come's out. Make sure level in tank is right and it has ports all around rim. they can be clogged up also.
You can use a roofing nail to stick in ports it is several around under rim that you can't see but are there where water comes out. Because if the ports some are stopped up it will restrict proper amount of water to certain areas.
Apr 13, 2010 | Toto Aquia II Dual Flush Toilet
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Washer will not fill to appropiate levels
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Jan 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Sterling 402315-0 White Windham Two-Piece Elongated Toilet 402315 Logo
210 people viewed this question
Top Sterling Home Experts
jmartin50
Level 1 Expert
Tim Whalen
Are you a Sterling Home Expert? Answer questions, earn points and help others
