Question about Konica Minolta magicolor 2430 DL Laser Printer
Konica Minolta Magicolor 2530DL
I love this printer but for some reason I can get it to pick up the laser photo paper I have. I have tried every paper selectiond it has any I deas
  • characterco Dec 08, 2008
    Same  14H error message on 2530dl.  Seems to have begun since we replace cartidges (not refills).  Was sporadic but now can't get a print.  Using 24lb laser paper.  Can't find the 'properties' tab to change the weight, in case that's the problem.
    Thanks for any help!
    karin
    New Friend:
  • 16 Answers
Open the top cover of the printer and remove the drum (piece with long green handle). Look down inside the printer and you will see a roller with ridges. Clean that roller with formula 409. Try not to use alcohol because it dries the roller.
If you are printing on paper thicker than 23lb. bond, you want to make sure you select "thick stock" for the media type on your computer.
For instance... in your application click on file and then print. In the print window select properties (usually). On the setup tab of the next window you will see media type on the right side. Set it to the type of paper you are printing on. This should make the printer pick up the paper slower.
If the paper is thicker than 90lb index (160 g/m2) it is too thick to go through the machine.
Posted on Jul 19, 2008
Konica minolta 2530dl fatal erro 15H
Check the transfer belt might need to be replaced.
Apr 26, 2014 | Konica Minolta magicolor 2300DL Laser...
Konica Magicolor 2530DL printing size mismatch....
check your media guides and check the user setting of the printer at the printer and compare at computer printer properties
Jan 17, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530DL streaks. maintenance
Lift drum out, look down behind toner and you will see a glass lens.
Clean it with a soft cloth or tissue. Works every time.
Aug 24, 2012 | Konica Minolta Magicolor 2530 DL Laser...
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
THE KONICA MINOLTA MAGICOLOR 2530DL/ ALL FOUR COLORS OF INK ARE LEAKING ALL OVER THE INSIDE OF THE PRINTER, WHAT WOULD CAUSE THIS?
Most likely reason is the printer is either a display model, or previously been sold and returned. The toner cartridges are usually sealed and these seals need to be removed prior to use. I would recommend returning to the supplier and asking for a new one, with the toner cartridges sealed. Once toner has been spilt, it is very difficult to remove all traces. A standard vacuum cleaner may be suitable to remove the worst.
Mar 08, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica Minolta 2530DL printer. I have
the reset is done via a 'first use fuse' in the drum unit.
check the contacts or put in a new one.
Oct 21, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I've replaced all neccesary ink colors and now my 2530DL Konica Minolta wants me to replace my Drum Cartridge... I don't know what that is or how to do it!
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
May 14, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta magicolour 2530dl
open side door and there is a transfer roller / one big black roller on the cover/ try reinstall it, maybe its not installed correctly
May 14, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
158 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
